Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-03-2011, 09:28 AM
slayer5's Avatar
slayer5 slayer5 is offline
Air bubble ?
I replaced head gaskets on my 95' 3.0 v6 . Also replaced radiator, thermo and all hoses. All working well but now, I have no heat, and a/t takes long time to shift into overdrive. Maybe thermo not working correctly ?
Old 07-03-2011, 11:39 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Air bubble ?
Did you install a 180 degree thermostat? Jiggle valve up?
Try running the engine on a hill with the engine uphill and the heater operating. This may burp any air in the system. Turn on the rear seat heater if you have one.
Check the operating temperature of the thermostat in hot water.
Make sure the heater valve is opening.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-03-2011, 08:08 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Air bubble ?
You may have an air pocket blocking coolant flow to the heater core.
Try burping it as Brian suggested.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 07-03-2011, 08:12 PM
danielsatur danielsatur is offline
Re: Air bubble ?
A garden hose and a little water pressure can force the air pockets out.
A prestone flush kit works best.
Old 07-03-2011, 09:38 PM
slayer5's Avatar
Re: Air bubble ?
When I replaced the radiator & thermo, I flushed it . I will do the hill trick as soon as I can. I didn't know I had to turn the rear seat heater to full hot with the front seat when burping. See, I live in Arizona, and its been between 100 and 116 degrees out. I use the air while driving in town and on highway. The clutch fan seems to engage fairly quickly and stay on while using air. Is this normal ? I don't get overflow boiling and overdrive works fine, but at night, OD takes awhile to work. Temp guage is just under halfway even with the air, but before I did head repair, it overheated on highway and the temp guage was reading ok til' I pulled over and shut off air, then while idling went up. So I am alittle nervous that its getting hot with guage giving a false read. What are some things air bubbles could effect besides no heat, and overdrive ?
Old 07-07-2011, 08:59 PM
fourwd1's Avatar
AF -Advisor
Re: Air bubble ?
Depends on where the bubble is located, could affect the heat and OD coming ON, if it's near the temp sensor it could confuse the EFI ECM making it think the engine is cold when it isn't, making it run rich ...
89 4Runner - stock
Old 07-07-2011, 09:44 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: Air bubble ?
Zero heat coming from the vents leads me to believe that the vacuum hose that goes onto the valve that allows heated fluid to pass thru the heater core is disconnected. You posted that you replaced the head gaskets........lot's of stuff to disconnect. This disconnected hose would cause the radiator fluid to NOT pass thru the heater core...thus...no heat. Could also be the reason for a late shift into O/D Vacuum leak=longer shifts at low rpm's when the engine should be pulling the most vacuum.
Old 07-10-2011, 08:09 AM
slayer5's Avatar
Re: Air bubble ?
I guess I should of said it had heat after I did heads, but very shortly. I am going to be working on it next weekend. I will check thermo, might have been faulty from store. I also just last week failed emissions test.(carbon monoxide and oxides of nitrogen) where too high. Any ideas ?
air bubbles on trans dipstick smantas Regal 1 05-14-2007 02:14 PM
Air bubbles in tranny fluid, 2005 4.2L V6 SwampRat013 F Series 2 07-09-2006 06:06 PM
Air bubbles? Sebstar Car Modeling 4 11-18-2003 12:20 AM
Tamiya Semi-Gloss Black X-18 / Air Bubbles djmr2 Car Modeling 12 07-01-2002 12:48 AM
Air Bubbles hAnGoOkNoM Car Modeling 7 04-15-2002 04:40 AM
