Old 07-01-2011, 05:28 PM
crackedvenom crackedvenom is offline
Leaking Oil [pictures]
My mom ran over something she thought was only a bag and now today i see there is a leak thats dripping pretty bad. I would just like to know any insight you might have on it. Thanks.
Im not sure why the liquid looks red in the picture but its def oil, as i used a white piece of paper to let it drip on. Must have been the flash or something.
Click here for pic, its pretty big though
http://tinypic.com/r/rwjshz/7
Old 07-01-2011, 06:35 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: Leaking Oil [pictures]
I suspect that fluid is red because it is actually transmission fluid rather than engine oil. The area it's leaking from is where the engine flywheel mates to the tranaxle (aka "transmission"). If it wasn't leaking until she ran over something in the road, then there's a chance the transmission housing is damaged. I hope that's not the case (no pun intended), and instead it's a seal. But, unfortunately the transaxle would need to be removed to determine why it's leaking, and that's not an inexpensive task.
The fluid appears to be in good shape (nice and pink). Is there a chance the transmission was recently serviced and maybe was overfilled? As the fluid got up to temperature, it started to vent out?
-Rod
Old 07-01-2011, 06:44 PM
-Rod
Well it wasnt recently serviced, but by the look of it, it didnt start until today judging by the puddle and the way its dripping. Its really hot out today also.
Old 07-04-2011, 02:39 AM
Knifeblade Knifeblade is offline
Well, let me ask the simple question, have you checked the fluid levels, oil, trans, radiator, to see if any have dropped? I'd suggest fill what may be low, drive it-or let it sit awhile, see if it drops again.
I'm leaning with shorod at this time, trans. fluid leakage.
An idea, was trans. fluid added recently prior to her incident? Could be just some overspill showing up, but I doubt it.
2000 Windstar transmission fluid leak olopezm Windstar 16 09-17-2010 08:51 PM
Oil Leak in radiator Southern Comfort Camaro Discussions 2 07-26-2009 09:40 AM
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 12:44 AM
Oil Leak - Oil Plug? Boloughlin 5 Series 2 07-09-2004 06:06 PM
Tags
car , leaking , oil
