Old 07-20-2009, 06:11 PM
Southern Comfort's Avatar
Southern Comfort Southern Comfort is offline
Oil Leak in radiator
Has any one had a problem of getting oil in their radiator.
Thanks,
SC
Old 07-20-2009, 06:23 PM
davebigs davebigs is offline
Re: Oil Leak in radiator
Does it look like transmission fluid ? What type of car.
Be not the slave of your own past. Plunge into the sublime seas, dive deep and swim far, so you shall come back with self-respect, with new power, with an advanced experience that shall explain and overlook the old.
Ralph Waldo Emerson
Old 07-26-2009, 09:40 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
any overheating? probably not.
-just change your engine oil. make sure it's not discolored (like chocolate milk). that would indicate coolant or some other watery substance getting into your oil - which could be a cracked engine block (very expensive).
- otherwise, highly likely, your tans oil cooler passage (inside the radiator) is busted. check your transmission fluid for the same. have the transmission oil changed anyway. all you have to do is bypass the transmission oil cooler in the radiator by installing an external transmission oil cooler. bout $25 comes with instructions, very easy to install. 2 ways to install it. Follow the instructions to install it without going thru the radiator. Go to a hardware store and get 2 screws/plug to plug up the holes now not occupied on your radiator. Make sure to use teflon tape or thread sealant. Guys at the auto store can help further. It's not very difficult.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Tags
leak , oil
