Old 06-26-2011, 09:57 PM
wpony1 wpony1 is offline
1996 windstar trans problem.
Hi everyone I don't post or check in here much but if I have to find something out this is the place I go to , Ok here is my problem I bought a 96 Windstar about 4 yrs ago and the transmission has always been a little quirky it runs great but to get it going I start out in 1st then up shift to 2nd then drive then its fine all day till I hit a stop sign when I will drop back into 2nd`then back up to drive but it shifts fine all the rest of the day as long as you don't come to a stop but today the OD light started blinking but it still seems to be shifting and driving fine but what is happening what should I be looking for I need help I am on a limited budget and need any help I can get thanks for any help or suggestions George
Old 06-27-2011, 08:08 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 1996 windstar trans problem.
Hi George,
I'm no expert but I'll try to help.
If you're on a tight budget it might be easier to have it diagnosed by a transmission shop or this situation could quickly become an endless money pit.
My first suggestion would be to inspect the Transmission Range Switch, it is a common problem with windstars and can cause funny shifting behavior. See if your van starts ONLY in P and N and if the backup light light up only in reverse. Failure of any of these will indicate a bad TRS switch and needs to be replaced.
Another possibility is to swap it with a friend's and see if the problem goes away. It sits on top of the transmission at the driver's side and can be traced by following the shift linkage to it. You can see it behind and under the air filter housing.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 06-27-2011, 08:41 PM
wiswind wiswind is offline
You may have a OBDII code stored in the computer.
For this, you can get your codes read for FREE at many auto part stores, like AutoZone.
Make sure to get the actual numeric code from them.
I have listed most of the OBDII codes in the sticky posts.
As mentioned, you may be lucky and have something simple, like the Transmission Range Sensor (aka neutral safety switch) or Vehicle Speed Sensor (VSS).
The other thing is to check the fluid level and check your records to see if you have changed the fluid, is should be changed every 30K miles for normal service, 21K miles for severe service.
The correct fluid is now Mercon V.
If the level is even slightly low, it can cause shifting issues.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 06-28-2011, 02:03 AM
Thanks for the ideas I will try and check some of them tomorrow the weird thing for me is once I start out the transmission works good and shifts perfect until I come to a stop Then I shift it into 2nd just to get it moving so it wont lurch once I am moving its as smooth at shifting as it can be thanks George
Old 09-19-2011, 08:53 AM
travis2822 travis2822 is offline
Send a message via Yahoo to travis2822
Where you able to find out what the problem is and fix it?
mom of 3 with 98 windstar trans problem lward Windstar 8 08-19-2011 01:39 PM
Windstar Trans problems Dobaroy Windstar 2 03-23-2010 03:27 PM
96 windstar 3.0L tramission problem Steve45ca Windstar 3 01-17-2010 04:56 PM
96 ford windstar trans problem jason walters Windstar 0 08-24-2008 06:35 PM
01 Windstar Trans Problem - Need Help !!!! stuartnh Windstar 17 02-23-2006 12:37 PM
