Old 01-17-2010, 04:08 PM
Steve45ca Steve45ca is offline
96 windstar 3.0L tramission problem
Hi, I have a 96 windstar, 3.0L engine.... the transmission seems to be slipping.... i can put it in park and it drives for about 5 secs then loses power and the engine just rev's. Turn the engine off anf back on then back into drive, i have power to the wheels again for approx 5 secs. this is the same in reverse. Any idea's or is the tranny done?
Old 01-17-2010, 04:18 PM
danielsatur danielsatur is offline
Re: 96 windstar 3.0L tramission problem
What doe's the transmission fluid look on dip stick while parked with the engine running?
Old 01-17-2010, 04:42 PM
it's red, at the full mark.
Old 01-17-2010, 04:56 PM
wiswind wiswind is offline
The fluid level should be checked with the motor warm, running at idle and gear select in PARK.
HOWEVER, I would give it a check with the motor off also.......the fluid level should be higher with the motor not running, and drop down some when the motor is running.
If this is not the case......it could be a pump problem.
Do you have a Check Engine Light lit?........or a flashing O/D light in the gear select lever?
Once you verify the fluid level.....the next thing that I would do, when this happens, is to select "1" or "2" instead of "D" and see if that helps.
Another thing that can happen is a defective Transmission Range Sensor (TRS).....AKA Neutral Safety Switch.
This part provides input to the PCM (computer) as to what gear you have selected.
A test that one can do........with the motor running......unplug the electrical connection to the TRS, and see if it solves the problem.
From what I have read, the shifts will be more abrupt, but it will shift.....providing that the problem was caused by the TRS.
You have to start the motor before unplugging the TRS because of the other function that it serves.......neutral safety.....preventing the motor from starting in any gear but PARK or NEUTRAL.
IF the fluid has not been changed for over 30K miles, it is due.
The correct fluid is a fluid that meets the Mercon V specification.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Tags
1996 , 3.0l , problem , tramission , windstar
