Old 04-17-2005, 09:18 PM
lward lward is offline
mom of 3 with 98 windstar trans problem
i am in need of help very badly.i have a 98 windstar and once it gets warm the trans slips outta o/d and will not go back into o/d unless u turn the van off and restart it.but still will only stay in o/d for a few miles.after drivin out of o/d for a few miles the o/d light starts flashing.what could b my problem?new trans?please help.
Old 04-18-2005, 08:49 PM
FORDTRACMAN FORDTRACMAN is offline
Re: mom of 3 with 98 windstar trans problem
Iward:
Any answer would only be a guess.You need to have the codes pulled (autozone)and report back with the codes.Autozone does not charge you anything for pulling codes.
Old 04-19-2005, 12:12 PM
Re: Re: mom of 3 with 98 windstar trans problem
Originally Posted by FORDTRACMAN
Iward:
thanks.will get 2 autozone soon and get those codes.hope nothing major.
Old 04-19-2005, 09:38 PM
wiswind wiswind is offline
OD light flashing is an indication of the computer sensing a problem with the transmission and / or associated electronics.
The transmission is electronically controled.....
Which leads me to hoping and praying that your problem is the sensor that is located on top of the transmission.... This is the sensor that "senses" what gear you have selected.....P-R-N-D. It is called several things....."Neutral switch", Transmission Range Sensor (TRS).....all the same thing. It can be bought at Autozone.....and is not real expensive......
It is a fairly high failure item.
Autozone has a website.... www.autozone.com that has a link to free repair information....which will have step by step instructions on how to replace the switch.
Old 06-13-2011, 12:28 PM
efvyka51 efvyka51 is offline
If no check engine light
possible causes:
Brake pressure switch under master cylinder---recall item
sensors: Vss if speedo not working
tss turbine speed sensor----disconnect wire--
see if trans stays in 4th gear
neutral safety switch
trans shops have speciol scanner tool
carefull!!!!!!!!!!!!! Trans shop always want to rebuild
Old 06-20-2011, 08:55 PM
You can have a working speedometer and STILL have the VSS be bad.
This is because there are 2 parts to the VSS.
The mechanical part, which is a direct connecton to the speedometer cable.
The Electrical part, which has a sensor that sends a electrical signal to the PCM (computer).
Mine failed in the electrical part, causing strange shifting issues because the PCM did not know how fast the vehicle as moving, so it did not "know" how to shift the transmission.
The speedometer (mechanical) was reading the correct speed.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 06-21-2011, 04:03 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I agree, mine starts to bounce when you get above 55MPH.
Wiswind, I believe that would be only for the 98 and older windstars, because 99 and newer have an electronically controlled instrument cluster which would only need the electrical part of the VSS. Right?
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 06-21-2011, 05:44 PM
tomj76 tomj76 is offline
Originally Posted by olopezm View Post
I agree, mine starts to bounce on you get above 55MPH.
Oscar.
I'd agree with that statement. In my '96 model year, an electronic speedometer was optional, and the mechanical speed is essentially independent of the electronic speed. I've found that the mechanical be read differently from the electronic by more than +/-5% and amount of error changes during an extended drive.
FYI, I had a bouncing speedometer which became very severe (+/-15 mph). It was difficult to know how fast your were traveling. Ford priced a replacement speedometer assemby at >$300. I sent mine to a company called Powels Speedometer, who repaired it by replacing the needle bearings for a fraction of the price.
Old 08-19-2011, 01:39 PM
Biker15k's Avatar
Biker15k Biker15k is offline
Send a message via AIM to Biker15k Send a message via Yahoo to Biker15k
I hope is is something simple for you but when my 99 started that OD flashing the tranny went out and i had to have it replaced.
Good Luck
~ Protecting those who can not protect themselves ~
