Old 06-17-2011, 02:55 PM
jaygio31 jaygio31 is offline
Found my tranny code, please help
i had my code read and they said it was VSS p0500. they als stated a couple other codes were coming cause of this including TCC stuck in locked position. Does this sound right, i am really close on my warranty and dont want them to string me along until it expires. will a ba VSS cause the TCC to be stuck locked
Old 06-17-2011, 05:17 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Found my tranny code, please help
A bad VSS can cause many different problems with transmission like strange shifting behavior, incorrect (bouncy) speedometer reading, harsh shifts and low fuel economy (thanks to Windstartled).
The best thing would be to have it replaced or do it yourself, it is a bit of a pain but with some patience it can be done.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 06-18-2011, 07:41 PM
wiswind wiswind is offline
Vehicle Speed Sensor is located on the back side of the transmission.....right over one of your catalytic converters.
It is held in with 1 bolt and has an electrical connection.
Make SURE to get the correct one for YOUR vehicle.......
I made it sound easy....but it is NOT easy to change, due to its location.
You can barely get your fingers onto it.
If you have the version with the speedometer cable connected to it....(mechanical speedometer), you can disconnect the speedometer cable at the "intermediate" location, under the flex hose that goes from the air cleaner to the throttle body.
Do NOT confuse this with the TSS Turbine Speed Sensor, which is mounted on the side of the transmission case, next to where the driver's side driveshaft comes out.
THIS sensor measures the speed of the shaft that comes out of the torque converter and goes into the gear input side.
As mentioned, a bad VSS can cause all kinds of problems as the PCM does not know how fast the vehicle is moving, so it does not know how to shift the transmission.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 06-18-2011, 11:05 PM
I had the tranny rebuilt almost 2 years ago about 20,000 miles and its just barely still under warranty so it will be a fix they are going to perform so I dont have to worry just yet
Old 06-20-2011, 08:49 PM
Absolutely get them to make good on the warranty.......you might get lucky and have that VSS take care of the other codes, but that Torque Converter Clutch stuck code concerns me as that can be a bit expensive to deal with.
1996 3.8L Windstar
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 02:27 PM
Found keyless code, need help using it. metaxlog Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 07-12-2004 10:43 AM
tranny problem? please help johnd89 LeSabre 20 01-19-2004 09:28 AM
Is My Tranny Gone?????? Please Help Redline_civic91 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 02-11-2003 03:20 AM
Manual tranny transplanter, please help WRAITH Engine 1 04-13-2002 10:32 PM
