Old 01-16-2004, 01:41 PM
johnd89 johnd89 is offline
Unhappy tranny problem? please help
Hello,
Sometimes (lately apparently more often), when I start the car in the morning and shift in OD to get moving, the car acts somehow like it's still in N, or barely moves forward. Then I have to apply the brakes and switch in R, then back in D, then it will go normaly.
A few time ago I had an error code (the check engine soon light came up) about the column shifter swich. It could be still that, or is it a sign the tranny will let go soon?
The car is a 91 park avenue with some 245k km.
Thanks a lot for any input!
Old 01-16-2004, 02:57 PM
comp comp is offline
have you checked the fluid level ? has it been serviced ?
Old 01-16-2004, 06:09 PM
thanks for the reply,
the fluid level is good and the tranny wasn't serviced lately (since I got the car...).
One thing that I noticed is that it did that the first couple of times when left outside at work in severe cold...
Old 01-16-2004, 09:30 PM
ok, smell the fluid to see if it's burnt, if your not sure buy a qt. of new fluid to use a a reference, for smell AND COLOR it needs to be red, not
brown, not reddish-brown, where do you live, how cold?
Old 01-17-2004, 12:03 AM
well, pretty cold, if I look closely I can see the polar bears-hehe- joke aside, some -45 F... but now I keep the car in a heated garage, but still it does that in the morning.
the fluid is more or less ok, I never changed it(in the last 20k miles since I own the car)... of course it isn't red like a new one, but not brownish, also it dosen't smell burnt. The tranny slips a little in third when going slightly uphill and I heard that if I change the fluid it will slip some more after... could this be true? If not, I'll go ahead and change it...
Thanks for the replys!
Old 01-17-2004, 08:39 AM
it needs service, do you have a good and honest shop you good to ??
in high mileage auto-trans cars with"slite" slippin and "morning sickness"
(when trans doesn't go till ready) i change fluid & filter, and use
CHRYSLER fluid ( dex-mercon + a friction modifier) if you have a reliable
mechanic talk to him about it, it's worked in more cars & trucks than i
can remember, also have had some luck with (hate to addmit) Lucas
trans treatment(don't tell) let me know
Old 01-17-2004, 09:27 AM
jim dillard jim dillard is offline
Re: tranny problem? please help
Does it go if you put it d? You may have wear in the shifting ass'y or bushings etc and when it looks like it is in gear it is not. One easy way to tell is if you can go from park to neutral try to start it in neutral. But really, 245k ? if it goes when you play with the shifter, play with it!
Old 01-17-2004, 10:37 AM
good catch Jim, i tend to assume the little things have been checked
that a s s u m e thing
Old 01-17-2004, 11:46 AM
well, I'll change the fluid then. what do you mean by a friction modifier? is it too a chrysler product? also, trans go makes a shift kit for those trannies
http://www.pro-built.net/index.cfm?f...&productid=158
do you think it will help?
thanks!
Old 01-17-2004, 11:59 AM
the fluid is made so the friction materials in the trans clamp and/or hold
better (clutch;band's,steel's) new fluid will carry more line pressure to,
(hyd. pressure) i'd be affaid to put a shift-kit in there to many
mile's, and it's weak now, so do you have a good mech. or are you doing
the service???
Old 01-17-2004, 12:04 PM
I understand that there are two options to change the fluid: one at a garage when it flushes the entire fluid, and the other (wich I can do myself) when only one third it's changed (by dropping the pan). wich one should I do?
thanks!
PS: I think I made a mistake, I change 4qt out of 12 pt, not one third...
Old 01-17-2004, 12:13 PM
i'm used to doing it myself,(i'd like the heated garage) i've READ good things about the flushing systems but don't have personal experience with them, on trannie problem's i take baby steps... called about a TURBO-350 i did same thing + added 1/2 qt. of the LUCAS
trans fix in , OK so far, don't try the lucas yet, it's thick, The lady is
tring to get trans to last till spring(tax check)
Old 01-17-2004, 12:26 PM
P.S. the fluid looks a little different, only use name brand, it sometime's
has a " + " on the bottle ,it should say for Chry. veh. let me know
Old 01-17-2004, 12:31 PM
P.S. #2 remember to use a quality filter also, (gettin old, dah!)
Old 01-17-2004, 01:39 PM
flyingpiranha flyingpiranha is offline
Question Re: Re: tranny problem? please help
Hey Jim,
I have a similar problem. My trans works fine except for one problem. When I put it into drive it will not engage until I pull the shifter back has far as it will go in the “D” position. Then it engages like normal. I can slide it back slowly from neutral to drive and nothing will happen. Then I tap the shifter back and it will go. I have had the transmission flushed. Someone told me that it was an actuator.
Do you have any ideas?
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 02:27 PM
96' Jimmy SLE Tranny problem - PLEASE HELP! edenweiss Jimmy 3 06-16-2005 04:17 PM
Tranny Problem Please Help lightnintko Integra 3 04-01-2005 07:59 PM
Tranny Problem, Please Help myhoe1997 C/K 7 08-10-2004 08:51 PM
Trannie problem, please help! trevelyanrules006 SC/SL/SW 4 07-06-2004 04:57 PM
