Old 06-12-2011, 12:23 AM
carguy9927 carguy9927 is offline
losing coolant and its pissing me off
I have an 01 Grand Prix GT with 164,000 miles on it and tonight for the first time my low coolant light came on then went back off while driving. I checked the radiator and there wasnt much in there so I went and bought some and filled it up. Then I was driving the car on the highway and the light came on again then went off. Does anyone have any ideas what could cause this?
Old 06-12-2011, 09:01 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: losing coolant and its pissing me off
Common leak spots on your motor include the Lower Intake Gaskets, tensioner bypass elbows, water pump, and the Upper intake manifold. Check near the injectors and the 90 degree elbows on the passenger side for coolant. There are 2 elbows, one is hard to see without removing the alternator.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 06-12-2011, 03:41 PM
danielsatur danielsatur is offline
Don't forget to check your electirc fans, after you get the pluming fixed.
Old 06-13-2011, 07:20 PM
FISH96 FISH96 is offline
you state you are a tech and very good at it. do you not have access to a cooling system pressure tester? this item will allow you to pinpont the leak. noted the year of your automobile and the mileage you may also have seepage at any of the crimped metal seams on the plastic tanks of the radiator.
it goes without saying, do not exceed the system's operating pressure limit with the tester. give the tester time and you will find the leak. good luck be patient, a good inspection mirror and a bright inspection light would be of great value with this task.
some of the items mentioned earlier in the thread are very slow leakers ie the cooling. elbows.
Old 06-22-2011, 09:33 PM
Thanks guys for your help. I dont think its the intake because it only leaves a little bit on the ground, and before I got the car the whole intake was replaced. When I stop somewhere I only notice a tiny bit. It's probably something small.
Old 06-25-2011, 11:58 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
If it's on the passenger side, it's the coolant passage elbows or water pump. Both seep as they start to leak, then get progressively worse.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-25-2011, 12:53 PM
Jrs3800 Jrs3800 is offline
We have seen some issues with the Elbows after a replacement.. Look at the location of the elbow coming out of the manifold.. You may have a leak there... If there is no evidence at all, Have a look at the weep holes on the water pump..
Old 06-25-2011, 07:37 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I agree with the elbows or water pump too, the elbows are on the tensioner asembly in case you don't know.
I would suggest you to take a look at the radiator passenger side cover, mine started to leak right below the filling neck and the result was a low coolant light everytime I started the engine, it would go away after a few seconds. One final possibility is the sensor has some goop on it. It's not that common but I've seen it in the forum. Members only cleaned it or replaced it.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
2002 w/ 3100 - losing coolant, and lots of sludge guitarfish Century 21 10-27-2014 06:33 PM
Losing coolant and oil Rkeefer23 F-Body Problem Diagnosis 1 05-08-2011 09:37 AM
2006 Cobalt losing coolant and running rough treehugger81 Cobalt 2 05-01-2009 09:26 PM
Girlfriend in tears and me pissed off. jon@af Stress Release 24 02-08-2005 11:09 PM
Who watches this crap on TV and gets pissed off? primera man COMPLETELY off-topic 47 11-11-2001 01:31 PM
Tags
coolant , grand , prix
