Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-17-2011, 05:47 PM
Rkeefer23 Rkeefer23 is offline
Losing coolant and oil
Unfortunately for me, I think it's a blown head gasket, but here's my symptoms.
'98 3.8 Manual Camaro 195k miles
- I lose oil fast enough to have to add a quart every month.
- I lose coolant fast enough to have to add between a half and a full gallon every few weeks (Dexcool).
- There is a white sludge type material under my oil cap, but the oil itself does not look milky.
- Sometimes my car knocks when I start it in the cold weather, but the knocking goes away when the engine heats up.
- Sometimes when I start my car it has white smoke coming from the back, but this is only in the cold weather and the smoke stops when the engine heats up.
- If I open the radiator with the engine running, I see some bubbles and the coolant will overflow when it starts to get hot.
-At my friend's shop, a device was placed on the open radiator as my car was running to test for fumes he said would indicate a blown head gasket. The color did not change and no fumes were detected.
I am afraid it is probably a blown head gasket, but I am not positive because it didn't "fail the test" and the smoke/knocking is only in cold weather. Plus the oil looks normal.
If it's not a blown head gasket, I can't think of what else would cause me to lose all the oil and coolant I am losing.
Any thoughts?
Old 05-08-2011, 09:37 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Losing coolant and oil
intake manifold gaskets are a common issue with the 3.8. I'm unsure if this would effect the oil loss, but with that many miles, you may have more than one problem on your hands.
2002 w/ 3100 - losing coolant, and lots of sludge guitarfish Century 21 10-27-2014 06:33 PM
Getting oil out of coolant mohammedsk Accord/TSX/Accord Hybrid 7 10-12-2010 09:58 AM
2006 Cobalt losing coolant and running rough treehugger81 Cobalt 2 05-01-2009 09:26 PM
Leaking Coolant and Oil..... tmanhardt Taurus | Taurus Wagon 1 11-21-2003 08:31 PM
Where on the turbo do the coolant and oil lines go?? Poweredbyhonda '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-03-2002 05:03 PM
Tags
coolant , gasket , head , knock , oil
