Old 06-07-2011, 03:38 PM
alero9110 alero9110 is offline
Aftermarket radio not turning on all the way
I am trying to install an aftermarket JVC radio in a 1997 ford taurus. i got the wiring harrens and the parts for the face plate. i have done this in a 09 taurus. but for some reason in the 97 the radio want turn on all the way. i can press display and the time, it will then light up and then turn off. idk if its the ground but I put in on the car chass and still nothing.
any help would be great?!
Old 06-07-2011, 10:21 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Aftermarket radio not turning on all the way
It sounds to me like you maybe don't have good switched power. If you had an open ground, you probably wouldn't even get the short burst of functionality. I suspect that the radio would still eject a CD even if you don't have the key on (with a correct installation) and that feature is essentially what you are experiencing. You could test this theory by temporarily hooking up the switched power to constant +12V and see if the radio basically functions like you would expect it to.
Have you confirmed that you have power where you should have power and that the fuses in the radio/harness are good?
-Rod
Key doesn't turn all the way back. tiffanyalero Alero 2 04-26-2007 02:41 PM
'91 Sonoma Key won't turn all the way in ignition vwneal Sonoma | S-15 1 11-04-2006 01:32 PM
Clunk when I turn all the way to the left Loaded Pampers Blazer 18 07-19-2006 11:18 AM
1988 - Key won't turn all the way DJ_Flipped Bonneville 1 07-01-2005 11:16 PM
92makes loud sound when wheel is turned all the way left! Srobocop 4Runner/GX470 11 01-07-2005 04:04 PM
