Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-01-2005, 04:12 PM
DJ_Flipped DJ_Flipped is offline
Send a message via MSN to DJ_Flipped
1988 - Key won't turn all the way
When I put my key into the ignition, I can only turn it as far as accessory. When I go to start it, it feels like it's blocked somehow. Would this be a problem with the ignition switch?
Old 07-01-2005, 11:16 PM
randman1's Avatar
randman1 randman1 is offline
Re: 1988 - Key won't turn all the way
Accessory position is acheived by turning the key backwards. Are you saying that you can't turn it forwards at all or you just can't get it to go to the crank position? Some older GM vechiels have a mechanical method of preventing the car from being started when the transmission is not in Park or Neutral. This is found in vehicles that have column shifters. My 90 SSE however prevents starting in gear electrically via a switch on the trans.
Can you clarify where your problem is?
