Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 05-20-2011, 01:10 PM
bigbleu515 bigbleu515 is offline
04 av door open buzzer doesn't work
hi everything is working perfect electrically except when the doors are open the buzzer stopped working.also when you manually lock the doors and walk away that alarm stopped working too............am i missing something? thanks for any help
Old 05-20-2011, 03:12 PM
j cAT j cAT is offline
Re: 04 av door open buzzer doesn't work
the noise maker is in the BCM...never got into that buzzer yet..the BCM is not made to be repaired ...if you got another it would need programing..
on a 1996 vehicle I own the buzzer is external. stoped working ..the cause was a wire that is part of the buzzer coil broke...manufactured too short...added an extention to it , then soldered into place.
when you lock the doors the horn sounds ????
lighted door key hole doesn't work 89 lebaron Lebaron 0 06-21-2010 11:05 PM
Door won't open StarSk8Grl13 6 1 04-19-2009 10:59 PM
door open alarm buzzer AutostradaVR4 3000GT/Stealth 4 05-04-2008 01:11 PM
how do i lose the open door/seatbelt buzzer? derekford Pick-Up 2 08-05-2004 12:59 PM
