Old 04-24-2008, 06:52 PM
AutostradaVR4 AutostradaVR4 is offline
door open alarm buzzer
it took about 3 years, but it has finally annoyed me to the point that i've gotta remove it. I was trying to hunt it down but cant find it, and i can only track the noise for about a minute before it starts to really irritate me lol. As far as i can tell it's coming from behind the radio...?
(i tried searching but i guess the terms are too vauge...no good results.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 04-24-2008, 07:47 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Re: door open alarm buzzer
http://www.3si.org/forum/f1/buzzkill-mod-311865/
Old 04-24-2008, 10:30 PM
thanks a bunch! this will give me something to do on my lunch break tomarrow
Formerly BlinkRA182
Old 05-03-2008, 11:52 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i didn't follow the link, but the buzzer is behind the radio. pull the radio (remove outer bezel, then remove 4 screws, and radio will pull out) then open the door, listen for the source of the sound. just unplug the buzzer, then you're good to go. it makes troubleshooting under the dash with the door open and key on much more reasonable.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-04-2008, 01:11 PM
Hotshot8792 Hotshot8792 is offline
no reason to even listen for the source of the sound, its on the inside of the right bracket towards the back. You can't miss it.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
