Old 05-12-2011, 12:30 PM
TLPHui TLPHui is offline
Send a message via Skype™ to TLPHui
Day Running Lights
My 02 Accord having problem with the Day running lights, the amber light "DRL" in panel is on and the running light is out, its supposed that the hand brake is released, the DRL light goes out and running lights are on. The other is the hood cable is so sticky, very difficult to close the hood, I tries to sprayed some WD40 on the latch, but doesn't work, is it possible to adjust the latch up and down to hold the hood? Any body knows how to fix it?
Tom
Old 05-13-2011, 12:32 PM
somick's Avatar
somick somick is offline
Re: Day Running Lights
I would start with checking fuses for DRL.
Try to operate hood release cable by hand. It may be just a bad cable.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 05-13-2011, 03:58 PM
Hi Sam,
Thank you for your advise. Actually, I have checked the fuse, they are all OK.
but I found that the Driver's side High Beam light is out, is this the reason to affect the DRL circuits?
Maybe I have to lubricant to cable end near the latch!
Thank you.
Tom
Old 05-14-2011, 08:44 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
The DRLs burn the high beams at lower voltage when the DRL is on, so if you have a high beam out, I suspect that's your problem, yes.
Most cars have a way to reposition the latch or the hook so they line up properly...usually just by loosening the bolts slightly and move it in the direction it needs to go...I don't know specifically on yours.
Also there are post with rubber bumpers on top, look kind of like little mushrooms, that support the hood when closed and are used to align it to the fenders properly. They simply screw in or out to raise or lower them. Sometimes one might have gotten spun and is too high, putting the hood in a bind and making it hard to open or close too.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 05-15-2011, 10:01 PM
After replaced with new High Beam light, now everything working good.
Re Hood latch - I have to check again and also the rubber support, it might be the problem from the rubber support.
Thank you all.
Tom
1997 Plymouth Voyager Parking / Running Lights - Dash Illumination Out levelbest Caravan | Voyager 3 09-25-2009 12:28 AM
Day Running Lights rkuchar1 Grand AM 20 04-24-2007 06:46 PM
Day running lights acting weird radeck Grand Prix 2 04-24-2006 11:51 AM
day running lights jakegday Cavalier 6 03-25-2005 10:12 PM
Day Running Lights free2roamaz Tiburon | Tuscani 2 03-01-2005 12:45 AM
