Old 02-17-2005, 03:17 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
day running lights
is there anyway to disable daytime running headlights, without disableing the highbeams, i found out if you pull up on the E brake just enough to get to the first click, this works fine, but then your brake light is on, any other suggestions would be greatly appreciated
Old 02-17-2005, 08:52 PM
KJRich's Avatar
KJRich KJRich is offline
Send a message via AIM to KJRich Send a message via Yahoo to KJRich
http://www.j-body.org/library/howto.php?6
1999 Chevy Venture LS Extended 3.4 V6 Intake Gaskets Replaced
2003 Cavalier LS Sport Coupe, 2.2 Eco, 5 speed Getrag, all black
Old 02-18-2005, 10:55 AM
billyboyb billyboyb is offline
Re: day running lights
why?????
Old 02-18-2005, 03:35 PM
Re: Re: day running lights
Originally Posted by billyboyb
why?????
well billybob, i was just wondering....
Old 02-18-2005, 03:48 PM
KJRICH, i tried the link you posted, it works, however the part it says about the passenger side high beam fix, by putting a little jumper wire in slot 30, and it slot 87a, mine are just labeled, 1 2 3 4 and 5, there is no 30 or 87a, do you have any idea which ones are which??? or does anyone else???
Old 03-25-2005, 09:37 PM
Governor Governor is offline
1=86
2=85
3=87a
4=30
5=87
1&2 are the coil
5 is ground
3&4 are the relay contacts
hope this helps..I have a 99 and currently my DRL and low beams do not work..pain in the arse!!
Old 03-25-2005, 10:12 PM
hey thanks alot, but i figured it out almost a month ago
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
