Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-07-2011, 05:12 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
97 Neon DOHC Engien problem
working on a 97 Dodge Neon DOHC, diff pin broke and shattered the tranny case, while replacing the tranny we rebuilt the engine. well the engine had a slight knock which got worse after a couple weeks. Tore the pan off and seen it had a spun bearing, replaced the crank, rods and pistons and all the bearings, seals and gaskets again. made sure all the clearances were within spec and everything was good. got everything back together and installed.
Started the engine, before installing the radiator and hoses and such, still had a knock ,after about a minute of running oil started pouring out of the back of the water pump/radiator hose connection. When we removed the pan we noticed coolant in the oil.
Any ideas what the problem could be besides head gasket?
I'm thinking a crack in the block somewhere, from the impact of the tranny shattering.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 05-08-2011, 02:42 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 97 Neon DOHC Engien problem
Cracked block or warped head.
2003 Dodge SRT-4
'99 Neon Highline Stereo Problem BarneyMobile 1st Gen 95-99 4 02-24-2010 07:50 AM
Wanted I Need A Neon Sport DOHC Cylinder Head 1997-Dodge-Neon Cars/Parts for Sale/Exchange 1 08-25-2009 11:23 AM
98 Neon 2.0 DOHC Starting Problem abcabc 1st Gen 95-99 7 11-06-2005 10:54 AM
stalling problem with 96 dodge neon dohc countrykitt66 Neon | Plymouth Neon 23 08-08-2005 03:40 PM
97 neon dohc problem!! speedster_74 1st Gen 95-99 3 12-05-2004 05:50 PM
