Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-22-2011, 08:14 PM
pencilneck0 pencilneck0 is offline
warning bell wont turn off?
I drive a 99 s/w 2 and this mourning when I arrived at work I got out of the vehicle and the bell that chimes when you leave the headlights on or the key in the ignition the warning chime would not turn off even though the keys were out of the ignition and the headlights were off,however it stops chiming when you shut the door.Any ideas?
Old 04-23-2011, 03:14 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: warning bell wont turn off?
If you don't hear a small metallic tapping sound after turning the ignition off (from the run position) and removing the key then the ignition lock cylinder is probably sticking after you pull the key out. It has a switch integrated into to it that enables the "slow" chime when you leave your key in the ignition and open the driver's door, but disables that chime when the key is pulled out.
It is the same mechanism that enables the steering wheel lock. Pull the small plastic piece off that surrounds the ignition and spray some silicone spray (NOT WD-40) in there. Then insert the key, turn to "run" then to off, pull out the key and repeat that a few times. That should help free it up.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 04-23-2011, 06:50 PM
Thank you ,it worked just like you said.She is as good as new
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 11:56 AM
Lights are on! warning noise wont turn off milat25 '97 - '03 3 02-21-2010 11:18 PM
Hedlights wont turn on but ambers wont turn off??!!!!!!!!!!!!!!!!!!!! mayhem143 '96-'00 Civic 0 09-12-2005 07:07 PM
my left turn signal wont turn off i-wsh-i-had-a-teg Galant 0 07-21-2005 02:34 PM
Brake lights wont turn off even when car is off... evaunit01 Corolla/Matrix/Voltz 2 04-17-2004 03:47 AM
