Old 04-08-2011, 05:53 AM
pcabn pcabn is offline
BCM Replacement
So as many of you know how the BCM Module gets corroded and does all kinds of great things, I have cleaned the corrosion twice and it works for about 8 months before it happens again. I read that if I replace the BCM, it will need re programmed. So if I get a new one can I install it and drive the car to get programmed or do I have to let them install it. Thanks.
Old 04-08-2011, 10:47 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: BCM Replacement
If it is a new unprogrammed BCM you will be dead in the water until it is reprogrammed using a GM Tech 2 scan tool.
What year and model Alero is this?
Timeslip 08/12/06
AF Community Guidelines
Old 04-09-2011, 07:29 PM
Re: BCM Replacement
01 alero 3.4 GLS. I read a post someplace on how water gets down in there. I am going to try to find it and follow the instructions on how to seal it up.
Old 04-16-2011, 05:57 PM
sightdev sightdev is offline
Re: BCM Replacement
water gets in from around the left front windshield. to seal the leak, spread away the weather strip and apply clear chaulking and slowly press down so it will squeeze deeper inside the crack. this is between the weather strip and the windshield grommet. its not just BCM getting wet but fuse box will also get wet causing havoc on electrical system. I have 99 and I did mine 5-6 years ago and have absolutely no electrical issues many post here. except for once, i have not experienced Passlock issue either. ODO on 130k, other than squeaky frontend, it still drives smooth and quiet with good MPG.
Old 07-04-2011, 12:25 PM
pleiku10 pleiku10 is offline
Re: BCM Replacement
Where can you buy one? I looked on GM parts direct and its not even listed. I have 2 broken pins from corrosion!! I've had so many problems with GM electronics failing, perhaps someday they will chose to spend a little more at the suppliers and get better quality parts!!!
Old 07-06-2011, 06:10 AM
Re: BCM Replacement
Bought mine used off of ebay. It worked but I still went to a GM dealer to make sure programmed correctly. They fixed something I just don't remember what. If you send an email I can tell you where I ordered it from.
Old 07-06-2011, 08:14 AM
Re: BCM Replacement
I bought one on ebay also, My wife does electronic work so I was planning to have her unsolder the pins and transfer them to the original board. How much did GM charge to reprogram your board?? Thanks-Mike
How to put BCM into program mode? (Where is BCM/MALL fuse?) copchick527 Grand AM 5 03-02-2009 03:30 PM
used bcm replacement tham1977 F-Body Problem Diagnosis 1 02-28-2008 12:12 PM
2002 Buick Rendezvous BCM Replacement cruiser18 Rendezvous 5 04-10-2006 10:09 AM
bcm replacement muggsie Impala | Impala SS 1 07-10-2005 12:24 AM
BCM replacement for 96 Grand Caravan DesertRose Caravan | Voyager 2 04-27-2005 11:40 AM
