Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 03-14-2006, 06:04 PM
cruiser18 cruiser18 is offline
2002 Buick Rendezvous BCM Replacement
Is the BCM something that can be replaced by me or do I need to take it to a dealer?Difficult or Easy?
Old 03-17-2006, 08:18 AM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
Re: 2002 Buick Rendezvous BCM Replacement
Physical replacement isn't that difficult I don't think, but it has to be programmed at dealer. Why do you need a new one?
Old 03-30-2006, 09:38 AM
Golferdude Golferdude is offline
I am about to replace my BCM also. I have talked with the dealer and it seems to point towards the BCM.
The problems I am having is the radio will go into "locked" mode, the traction will go off, it will go ding ding ding..display message center will say "service engine soon".
The dealer told me that the BCM didn't have to be programmed. Is this not correct?
Thanks...
Golferdude
Old 04-06-2006, 09:59 AM
To the best of my knowledge (I have Pontiac version), the BCM does have to be programmed to have things work correctly. I did hear of one person (Pontiac again) who obtained a used one that at least sorta worked (not everything was quite right though). Also of possible interest, I heard one one person that was having BCM related issues that took some time and cleaned all the connections to BCM and also fuses related to BCM stuff with electronic cleaner to clean up oxidation (corrosion)and surprise surprise their problems all went away and have not returned yet. That is something I have suggested here and there as possible solution, but its the first time I've heard of it being tried (and it appears to work, in at least this case)
Old 04-07-2006, 08:45 PM
I did have to get it reprogrammed.
The airbag rediness light stayed on and the radio was "locked". I took it to the dealer, they charged $49 to reprogram it and everything worked great. That was yesterday.
This morning, my wife went out to go to work, put the key in, tried to start it, and nothing. The radio came on, blower came on, but nothing. So now I am trouble shooting that. Someone told me to check to see what the "Security" light does when the key is on when it won't start and check the voltage to the starter solenoid.
So that is my next mission.
Old 04-10-2006, 10:09 AM
Golferdude , I think I would be real suspicious about battery/cable connections/charging system. The electronics are pretty sensitive to voltage flucuations and BCM stuff can be affected first. I could suggest getting an active load test of battery/charging system
