Old 03-31-2011, 04:10 AM
knightjp's Avatar
knightjp knightjp is offline
Engine Size and Cubic inch
I know this must be a stupid question, but me and my dad were talking about engine sizes and how its calculated... like for instance...
427 Ci - Does this mean the block size or the whole engine???
Another question is on litre...
I'm a little confused on this.... how is this calculated???
Is 5.3L the size of whole engine or the cylinders???? Someone told me its the cylinders...
Old 03-31-2011, 06:02 AM
snshddog snshddog is offline
Re: Engine Size and Cubic inch
As the name Displacement describes, it is the difference in the size of the cylinder compaired from the piston at the top then the bottom of the cylinder. It is the difference across the entire engine. Liters is just the metric conversion of it.
In a nut shell, it is the size of the holes the pistons go in.
The Following User Says Thank You to snshddog For This Useful Post:
knightjp (03-31-2011)
Old 03-31-2011, 06:54 AM
knightjp's Avatar
So its not the size of the complete engine with headers, etc???
Let me get this right...
Is it the size of all the cylinders in the engine combined???
Old 03-31-2011, 09:53 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
It is only the sum of the volumes of the cylinders within the block. All the rest just contributes to strength, cooling, etc.
1 liter (L) = ~61 cubic inches (cu in)
For a 427 CID (Cubic Inch Displacement) V8 engine, or 7.0 L, each piston would displace 427/8 = 53.38 cu in, or 7.0/8 = 0.875 L
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
The Following User Says Thank You to jdmccright For This Useful Post:
Old 03-31-2011, 10:49 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Cubic inch displacement:
Cylinder bore * bore * stroke * # cyl * 0.7854 = cubic inch displacement.
For example, a Chevy 350 engine, which has 8 cylinders, a 4" bore and a 3.48" stroke:
4 * 4 * 3.48 * 8 * 0.7854 = 350 (actually 349.858 rounded up).
The same formula works for determining metric sizes as well, just use the proper numbers.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
The Following User Says Thank You to silicon212 For This Useful Post:
Old 04-03-2011, 03:43 PM
knightjp's Avatar
Ford displacing 589 cubic inches (4.627 bore x 4.375 stroke)
What is the size of this engine???
Old 04-04-2011, 01:23 PM
jdmccright's Avatar
The RustBuster
Use the conversion I gave earlier: 1 liter = 61 cubic inches (Hint: divide by 61 to get liters)
589 cubic inches IS the size of the engine that is referred to by manufacturers, gearheads, etc. External dimensions aren't used to identify engines.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
knightjp (04-05-2011)
Old 04-04-2011, 07:49 PM
534BC 534BC is offline
This help? https://www.pamperedchef.com/orderin...=210&words=cup
Don't laugh.
The Following User Says Thank You to 534BC For This Useful Post:
Old 04-05-2011, 03:56 AM
knightjp's Avatar
Originally Posted by 534BC View Post
Ah yes... this was helpful...
Old 04-15-2011, 09:57 AM
carbuzzard's Avatar
carbuzzard carbuzzard is offline
Basics: volume of a cylinder = (πrr)h. OK, this forum doesn't have mathematical notation, however, it comes out something like "pi times the radius squared times height."
Translate that into common engine terminology, well, pi is 3.1415...etc. It keeps going but that's enough. "r" or the radius is half the diameter, otherwise known as the bore. Height is the stroke.
So to find the volume (or displacement) of one cylinder, divide the bore in half and then multiply that by itself and then multiply that times 3.1415. Then then when you get that number, multiply it times the stroke.
Then to find the overall size of the engine, multiply that times the number of cylinders.
Of course, if you want to talk about the displacement of a rotary engine--like a Mazda RX-8's--you're on your own.
Spam link removed by moderator. We're watching you!
Old 04-15-2011, 04:24 PM
knightjp's Avatar
Thanks for the info....
I wonder how they calculate the displacement in those rotary engines...
Old 04-17-2011, 09:40 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Think of an engine's displacement (size) like a hypodermic needle. The plunger is the piston, the body is the cylinder, and the needle is the valve. As you draw the plunger back a certain distance, it sucks in a certain amount of heroin... I mean medicine.
Changing an engine's displacement means you either have a larger diameter syringe (piston and cylinder) or draw the plunger back farther (increase the stroke length.) So, an engine's total displacement is the volume of each "syringe" times however many cylinders there are.
In this way, one engine block can have many displacements. The small block chevy is a good example. Within one basic block, they made displacements from 265 cubic inches up to 400, and with aftermarket parts you can go as far as 450+ cubic inches.
Dragging people kicking and screaming into the enlightenment.
Old 04-18-2011, 12:30 AM
knightjp's Avatar
As far as what I've heard, the engine displacement comes from the size of the cylinders in the block. How is it that it can be increased by adding aftermarket parts???
Old 04-18-2011, 04:44 PM
That's almost as bad as my pampered chef measuring cup.
Old 04-18-2011, 04:46 PM
Bore the cylinders out to make them larger diameter (with corresponding larger pistons)
Install a crank w/ longer throws making the length (stroke) longer.
Engine Coolant and Heater on a 1990 Cadillac DeVille? butturinij@uwplatt Deville 2 11-03-2009 09:04 PM
22,24,26 and 28 inch rims for sale calvin.lewis20 Cars/Parts for Sale/Exchange 0 09-30-2009 07:30 PM
1998 Mustang V6 engine knocks and runs rough birdstash Mustang Problem Diagnosis 2 06-04-2009 09:59 PM
Engine Size and Starter i_cry_at_night Type 1 5 05-22-2006 10:18 PM
engine size and name Ringo234 Camry/Camry Hybrid/Vista 1 08-07-2004 10:35 PM
