Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-04-2009, 09:05 AM
birdstash birdstash is offline
1998 Mustang V6 engine knocks and runs rough
I have a 98 v6 mustang that ran great and all of a sudden, it wouldnt start. so, i used starting fluid and it started. It ran fine, I let it run for an hour or so, took it for a spin, and when accelerating, it made a little knocking noise. So, I parked it, and the next few times I tried to start it, it wouldnt start. When I finally did get it started, it knocks really badly,runs rough and wont stay running for more than a few seconds. I had it towed to a shop, they said the fuel pump was bad. I relapced the fuel pump and the problem persists. The fuel rails are full of fuel too. Any ideas?
Old 05-04-2009, 07:57 PM
rhandwor rhandwor is offline
Re: 1998 Mustang V6 engine knocks and runs rough
Did you ever loose oil pressure?
Roll it over by hand to TDC tell use where the rotor button is located.
Did it over heat prior to this happening?
Old 06-04-2009, 09:59 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Could have spun a bearing. Sounds to me that the problem lies internally inside the motor. Also, I've had bad experience with starting fluid..
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Tags
engine , knock , mustang , v-6
