Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-24-2011, 11:01 AM
67malibu 67malibu is offline
Replacing a tire pressure sensor
2007 impala - I'm going to replace a sensor and am wondering if I tell the car to relearn the tire positions, will it recognize the new sensor or is there some special reprogramming procedure? The new sensor is a Dorman direct replacement unit.
Old 03-24-2011, 01:25 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Replacing a tire pressure sensor
There should be some information about this in your owner's manual . Good luck !
" Sometimes I grow so tired "
Old 03-30-2011, 09:04 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
You will need to program the sensor. The easiest way to do so is once you get the sensor replaced. Turn the ignition to the on position and press and hold the lock and unlock button at the same time on your keyless entry transmitter. The horn will beep twice and this signals the learn mode. If you do not have a transmitter apply the emergency brake and turn the headlights from off to on 4 times. The horn will beep twice signalling learn mode as well. Starting with the left front (driver's side) tire, either air up the tire or let air out of the tire. The horn will beep once, after that go to the right front (passenger side) and repeat. Then the right rear (passenger rear) and finally the left rear (driver rear). Each time you air up or deflate the tire, the horn will beep and on the last tire it will beep twice signalling that you are done. And from here the TPMS sensors should all be programmed
Old 04-03-2011, 07:19 AM
Thanks, the owner's manual actually had that procedure written in it. That's first time I've seen GM actually put something useful in an owner's manual.
04 tire pressure sensors deactivation Lexi James Expedition 0 05-23-2005 09:56 PM
how do u change the tire pressure sensors to new rims? caroquintero_156 Yukon 10 05-03-2005 03:54 PM
Tire Pressure Sensors Aurora01 Aurora 5 04-15-2005 11:07 PM
Where are the tire pressure sensors??? 94sportsedan Grand Prix 9 12-26-2004 08:13 PM
Low Tire Pressure sensor blackalero Alero 6 09-07-2004 09:06 AM
