94 k1500 stalls at take off
I have a 94 4x4. I have replaced spark plugs, plug wires, fuel filter, and rotor cap and button. In the mornings when i leave the house and take off it seems like i am trying to push another vehicle or somthing. sometimes it will miss spit and sputter and stuff. Some times it dont miss. After i go 2-3 miles it will stop missing and run fine. I have tried running only 93 octane, and still no difference. All plug wires are up off of everything and both injectors seem to be doing right. I am to the point I dont know what to try next. If someone knows anything I should try let me know please. Thanks for any help. Also one more thing, sometimes going down the 4 lane 55 or so it will start missing or feel that way. I can let all the way off the fuel and it will stop and run fine. I dont know if this has anything to do with the other problem or not.
Re: 94 k1500 stalls at take off
Pull the vacuum line off the EGR valve, cap it, and try it like that. If it runs good, you need to replace your EGR Valve. It is located on the Lower intake on the passenger side.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
| The Following User Says Thank You to tblake For This Useful Post: | ||
chevy_29 (03-23-2011)
Stored codes?
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
| The Following User Says Thank You to Schurkey For This Useful Post: | ||
if the engine runs like it is not getting enough fuel when cold this is the ECT. this may be out of cal. if so the computer may think the engine is warm when in fact it is cold. cheap/easy part to replace , probably the original........... with missing on the hywy speeds sometimes , I would use an OHM METER and measure the spark plug wire resistance. If you find resistance too high on some[one] get new wires and check resisitance before installing...............If your lucky. |
| The Following User Says Thank You to j cAT For This Useful Post: | ||
I did try this and there was no change. I went ahead and replaced the EGR anyway.Thanks
I dont know i have not checked this. I will though. I have replaced the fuel filter and i fotgot to say i replaced the fuel pump also. It went out around 3-4 months ago. It was doing this before the fuel pump went out too. Thanks
ECT is the Engine Coolant Temp (sensor).
So you replaced the EGR even though you didn't need one? ouch, how much that set you back?
You could also check if the IAC is stuck open and/or the throttle plate is sticking while the truck is in Park. Also check for vacuum leaks (spray all around with carb cleaner) and a stuck closed warm air diverter (in the air filter snorkel).
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
$40.00 my buddy has a transmission shop and he has a ton of older parts still in boxes sitting on shelves. I was going through everything one day looking for somthing and I ran across that. Luck
i'm glad i seen this post on checking with carb cleaner awhile back people was get on me said not to use and if i could'nt hear and find vacuum leak i've always used carb cleaner to find it thanks alot.
carb cleaner is for metal only ...................... |
might if you spray it like painting a car.
I have used card cleaner and also ran a water from a water hose to find if i had a vacuum leak when i did not have any carb cleaner. I am sure if you sprayed carb cleaner on everything 15-20 times you might eat up somthing. As far as i know i have never messed up anything with it. glad you got to see this post
GM does not recommend any carb cleaner to be used to clean the throttle body/IAC/MAF as this damages these components. some gaskets are not made to be exposed to carb cleaner. damage takes some time to develop.. |
