Old 03-16-2005, 12:20 AM
spunger spunger is offline
Taking off front d-shaft, 91 k1500???
Hey guys,
My front output shaft seal in the T-case is leaking. I went and tried to get the driveshaft off today and the damm thing wouldn't come off. I ran into a problem.
1. The driveshaft spins no matter what I put on it to keep it from NOT spinning
2. I have nothing to clamp to so removing the flange bolts is near impossible
3. I got frustrated and gave up
Where the driveshaft connects to the trans case it's a flange of some sort, 4 bolts that hold it, but I can't hold it to loosen the bolts up and then I'll run into a problem trying to hold the yoke from spinning so I can change the seal. I'm wondering is there some trick way of holding the driveshaft so it doesn't spin? I thought about putting the truck into 4wd and loosen them that way but I dunno how strong that chain is inside the T-case (or gears if that's what's inside). It's a NP241 T-case.
Any help on this would be great. I got the seal, seal install tools, ATF, all the good stuff to get the seal out and a new one in but I need help on how to make it so everything doesn't spin while I'm trying to do this.
Any help would be great.
Chris
Old 03-16-2005, 02:30 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Taking off front d-shaft, 91 k1500???
If you have questions about the t-case being strong enough, put it on the ground and block the wheels, but it should be plenty strong. If not already, use penetrating oil.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-17-2005, 09:36 AM
cdoogles cdoogles is offline
Re: Re: Taking off front d-shaft, 91 k1500???
Soak the bolts in some remover fluid or brake fluid in really stuck. Then put the truck on the ground and shift it into 4wd Low. I dont know that the Low part makes a difference, but its what I always do! Then try and break em' loose...shouldnt be too bad if you have at least an 18" breaker bar/ratchet. Good luck!
Old 03-17-2005, 07:17 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Think about the power that goes through the t-case to the front end, from the engine.
There's no way that you, loosening a little bolt, will be more powerfull than the engine ever is.
You will not hurt it...put it in 4wd and start loosening the bolts.
