Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 03-19-2011, 11:15 PM
rastenborg rastenborg is offline
Gear Oils
Manual Transaxle: 1.3 qts Gl5 SAE 75W-90
Rear/Front Differential Oil GL-5 SAE 90W R 1.6 Front 1.3 Qts
Transfer Case fluid GL-5 SAE 75W-90 1.8 Qts
Uhhhm, Would Wal Mart GL-5 80W-90 be OK for all applications?
The 75 is a little lower than 80W
Minot ND-Winter: -20 to 20 Degrees most days.
Summer: 50 -90
Some very cold nights and Some very warm days with a 110 Degree Temperature Variation.
Plus: 4WD works fine in Low Range. The on the move High Range makes noise.
Is the 4WD Tranny a separate part form the 2WD Tranny? Looking to find a used 4WD and then swap out.
How do i change gear oil? JDM00CivicEX Engineering/ Technical 2 06-17-2003 11:01 PM
when to add gear oil BLU CIVIC '88 - '91 Civic | CRX | Wagon | Shuttlee 40 06-02-2003 12:22 PM
YES! I just bought GL-4 gear oil! Finally! NismoPC General 5 03-05-2002 09:48 PM
Is (GL-3,GL-4, GL-5) ok or do I need ONLY GL-4 gear oil? NismoPC Maintenance 3 02-28-2002 06:31 AM
