Old 05-17-2003, 11:46 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
when to add gear oil
how would i know to add gear oil to my tranny itz makin noises and itz not my throw-out bearing.....was just at a friends shop and they just changed out an integra tranny b/c they told him to add gear oil and he never did....help is appreciated
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-17-2003, 12:12 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
If it drives crappy I guess you could always refill it. It's easy. Take off the starter and under that is the fill hole. You drain the tranny by removing this bolt very low on it. Then you take off this other bolt and fill the tranny until fluid pours out of that hole. Thats it. Mine drives really good with new fluid.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 05-17-2003, 12:16 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Everytime I shift into 3rd my syncro grinds. You guys think if i change the tranny fluid that will go away ? Or and i going to have to live with that awfull noise?
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 05-17-2003, 12:17 PM
It might fix it. Throw in some Lucas Oil and that could stop the grinding if its not too bad.
Old 05-17-2003, 10:16 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
NEVER NEVER NEVER NEVER NEVER
NEVER use gear oil in a Honda/Acura Transmission. Honda SPECIFICALLY states not to use anything other than 5w30 or 10w30 conventional motor oil.
If your trans is making noise, and your oil level is good, there is nothing you can do except to properly service the transmission.
Old 05-17-2003, 11:18 PM
crx hf crx hf is offline
My friend works at grease monkey and he says the best oil to use for a honda tranny is 10w30 MOBIL 1
Old 05-17-2003, 11:24 PM
Im not sure if synthetic is bad for the trans or not.
I do know that Honda oil is 10w30.....I've seen it in person.
All it really is, is a re-packaged oil bottle with honda info on it. I think its valvoline, not sure though.
Old 05-17-2003, 11:36 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
what about all those guys who throw the GM shit in it?
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 05-18-2003, 03:27 AM
BullShifter's Avatar
the level should be at the bottom of the fill hole w/ 5w-30 or 10w/30 motor oil.
Old 05-18-2003, 05:13 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah i had a question about tranny fluid. is that gm syncromesh stuff ? where do u get it?
Team Lonely Drivers
Old 05-18-2003, 05:48 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Honda doesnt recomend oil for thier manual trans...they recommend thier own manual tranny fluid...but to each his own i guess....\
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 05-18-2003, 05:51 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
All you have to do to check the tranny is get underneath and you will see 2 bolts on the tranny, i think they are like 22-24 mm or maybe just a bolt with a square hole in it, like you can put a ratchet in. Well common sense tells you that the bottom one will drain the tranny and the top is used to check it. the fluid should be right below the hole, or sometimes it will start pouring out, either way its good, just replace the bolt and then try and figure out what else could be the problem.
Note: That requires no disassembly of anything.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 05-18-2003, 05:58 PM
gunnmen01's Avatar
the drain bolt is a 3/8's ratchet and the fill bolt is above and behind it....its a 17 mm bolt...
gunnmen01
Old 05-18-2003, 05:59 PM
Tony's Avatar
TLD Member #1
gunnmen01
yours is 2 different sizes. I work at a oil changing place so I deal with this shit all the time, they are all usually the same, including mine. I just forgot what it was
Tony
Old 05-19-2003, 01:14 AM
You're missing the point.....Honda Manual Trans fluid IS oil. Its 5w30 conventional motor oil.....And of course they're not going to recommend anything else, because they want you to buy the HONDA oil....
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
