Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 03-18-2011, 01:54 AM
chriseisenbraun9 chriseisenbraun9 is offline
Engine cuts out when you hit the gas hard, but not when lightly accelerating
I bought this van about a month ago. Motor was knocking, previous owner drove the thing for months having to dump multiple gallons of antifreeze in it per week, so i didnt want to rebuild the whole motor and my mechanic that I use for jobs to big for me said he had a 3.1L out of the same year grand am. motor came out of a friend of mines car and ran perfect after the car was wrecked. Anyway i had the motor put in my van for a total of $700. it starts up and idles perfect and runs fine if you accelerate very lightly, but as soon as you press the pedal harder the motor cuts out and starts horribly misfiring. you could be at 3k rpm and push it in harder and it will immediately drop below 1000rpm and the check engine light comes on. i have a code scanner and only code is a random misfire
Ive only put about 10 miles on it since i want to get it fixed before driving it much. I disconnected the MAF and it is a LOT better but still does it. Plus the engine light comes on for the maf right away when i disconnect it. I brought the maf inside and cleaned it with carb cleaner and let it dry overnight and it made no difference could i need to change the MAF to the one for a 3.1L?? or do i need to drive it some so the computer need to relearn the motor?
Old 03-18-2011, 01:15 PM
Re: Engine cuts out when you hit the gas hard, but not when lightly accelerating
little update i took it for a 20 mile or so drive and it runs ok now up to half throttle but anything over that and it starts misfiring like crazy.. and now im getting a check engine light for the MAF low input..
Old 03-18-2011, 05:42 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Sounds like it's missing under load?
Did you check the ignition system on the motor before fitting it?
It may be grounding under load, or the coil may have failed.
Old 03-18-2011, 09:03 PM
Actually i figured it out, i bought a new mass airflow sensor today and swapped it and it runs perfect, Its amazing how just a sensor on the intake can make it misfire so horribly. Anyway if anyone else has an issue like this try the MAF, not cheap but if its not the problem you can always return it,
Old 03-18-2011, 09:14 PM
Moppie's Avatar
Master Connector
Sweet!
Glad you got it working again. It's always a nice feeling to figure it out and get a car going again
Old 03-26-2011, 08:37 AM
LMP's Avatar
LMP LMP is offline
What year is that 3.1?....the original..and the replacement...cause early 3.1 TBI and even MFI did not have a MAF (mass air flow)....they had a MAP (manifold pressure ). MAF was the exclusive of the 3.8
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 03-30-2011, 02:45 PM
merc81 merc81 is offline
'99 and up would have both a MAP and a MAF sensor. . .
Old 04-02-2011, 08:29 AM
LMP's Avatar
LMP LMP is offline
yeah....3.4 then..
90 tbird sc runs great but stutters when i hit the gas to hard? thunderbirdsc Thunderbird 0 02-04-2010 02:39 AM
E150 idle ramps up and down; dies when you hit the gas crcrowe1 E Series 0 10-04-2005 12:05 PM
98 ram idles but dies when you hit the gas pedal TazAngel Ram Pickup | Ram SRT10 6 05-05-2005 03:54 PM
My Car Dies Out When I Hit The Gas Hard LAWRENCEFLORES '88 - '91 Civic | CRX | Wagon | Shuttlee 4 08-06-2004 02:53 PM
Car cuts off when I hit the gas escortservice Escort 3 05-03-2004 09:36 AM
