Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-19-2005, 04:10 PM
TazAngel TazAngel is offline
Send a message via Yahoo to TazAngel
98 ram idles but dies when you hit the gas pedal
We recently put a new engine in our truck and it starts but as soon as you rev the engine up, it dies and won't start for several hours. The check engine light was on so we checked the codes which was the idle control sensor and the vechicle speed sensor. We replaced the idle control sensor but that didn't help. Don't know if the speed sensor would help. Any suggestions? Someone said maybe our ECM is bad?
Old 04-20-2005, 01:34 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 98 ram idles but dies when you hit the gas pedal
as bad as this may sound, could be a bad fuel pump.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 04-20-2005, 11:29 AM
That was replaced just before the engine gave out
Old 04-23-2005, 02:46 PM
CrucialConcepts CrucialConcepts is offline
Send a message via AIM to CrucialConcepts
You may have to re-configure the ECM to the Motor since its a swap out.
Visit my site www.CrucialConcepts.com
The 1 Stop Shop 4 All Your Automotive Needs!!!
Old 05-03-2005, 06:09 AM
Klaz28 Klaz28 is offline
What motor do you have? Is it multi port or throttle body?
Have you checked the tps(throttle position sensor) that could be the cause. I would say the idle controll should be ok if it idles. Did you mean speed density sensor? IF so it could possibly be that. After replacing sensors it's a good idea to reset the ecm, usually disconecting the battery for 5 mins will reset it. Also pull and inspect the plugs making sure to note which cylinder they came from.
Atleast Ford knows how to circle their mistakes!
Old 05-03-2005, 09:11 AM
Well, we finally had it towed to a shop this past friday and picked it up today. One of the lifters was turned a little when it was put back together and the distributer was turned wrong and the wires on wrong. But thanks for all the help everyone. Hopefully this will help someone else.
Old 05-05-2005, 03:54 PM
yeah that'll do it..always remember the basics when diagnosing a motor.
Three essentials for a motor to run: Ignition, Compression, Fuel.
