Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-13-2011, 05:22 PM
463's Avatar
463 463 is offline
3500 water pump
2006 impalla 3.5, how many miles on the water pump before they leak?
Old 03-13-2011, 07:15 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 3500 water pump
Difficult question to answer , my 2000 Impala 3.8 L made it to 130,000 miles ( over a 10 year period ) before it started leaking ! Yours may be less , may be more ?
" Sometimes I grow so tired "
Old 03-13-2011, 08:39 PM
463's Avatar
463 463 is offline
Re: 3500 water pump
the car has 142000 and it looks stock.
Old 03-13-2011, 09:14 PM
Blue Bowtie's Avatar
Registered Offender
Re: 3500 water pump
Why are you concerned? Is there a rumor around about failures? I remember back when a water pump was about a 60K mile maintenance item, and exhaust systems would last about 3-4 years no matter what. Those were the old days. 100,000 hour bearings are very common any more. Poly-V belts (serpentine) use automatic tensioners so that accessory bearings don't get overloaded like they used to. Water pumps tend to erode less and the pump seals are lubricated better with the newer coolants. Still, if it's a weak point it might be a good preventive maintenance measure, especially if a leak will cause other damage (like the LT1s suffered).
Costs on water pump for 97 Grand Am? CindyLynn Grand AM 1 12-02-2010 02:06 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
