Old 03-12-2011, 12:44 PM
heymanz heymanz is offline
alero still shuts off
2000 alero still stalls n wont start someone else on here had a problem with the bcm under the passenger side of the dash would that cause a starting n no start problem it cranks over but wont start. thanks for any imput.alero still shots off
Old 03-13-2011, 11:02 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: alero still shuts off
It would help to post which engine you have and mileage.
Have you checked fuel pressure?
Timeslip 08/12/06
AF Community Guidelines
Old 03-14-2011, 01:32 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
X2, do what Bob said, he knows his stuff.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-14-2011, 01:52 PM
it is a 3400 v6 with 118000 miles fuel pressure is 45 to 50 lbs it seems to run a few seconds but wont keep running then it may run n beabler to drive
Old 03-14-2011, 01:56 PM
danielsatur danielsatur is offline
Change both the fuel filter & air filter.
1) Do another fuel pressure test. >41psi might indicate a bad fuel pressure regulator.
2) Do a Catalytic converter back pressure test.
02 Alero shutting off while driving Troyk188 Alero 2 02-03-2011 09:38 AM
99 alero starts shuts off immediately jace77 Alero 3 10-04-2008 07:59 AM
Alero Shut off at light while driving tupa Alero 7 07-29-2008 05:38 PM
2000 Alero shut off and won't start darnsuprat Alero 2 02-25-2008 09:24 PM
still having problem with shutting off wally91vhevrolet C/K 4 11-15-2004 04:55 PM
