Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-27-2003, 12:05 PM
87' lude 87' lude is offline
b20 vtech head swap
i have a '87 prelude si with a b20 in it. i was wondering how hard and expensive it would be to put a 16v dohc vtech head on it. and how much electronical work would be needed to hook up the vtech.
Old 05-30-2003, 12:40 AM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
pretty damn hard.
the frankenstein b20-vtec setup is generally the later b20z from the crv, which the vtec head will bolt to.
tom at www.ludespeed.com had a write up on the vtec head swap on the b20a though, and it can be done, but it requires redrilling some holes and what not.
it's not worth it.
Old 05-30-2003, 03:05 PM
sloth__316 sloth__316 is offline
would that even match with it
JOSH C. HARMON
Old 06-04-2003, 07:31 PM
Ephram Ephram is offline
Originally posted by flylwsi
pretty damn hard.
it's not worth it.
it is worth it if you do a cam swap also. if not then the gains are insignifigant.
but another thing costing a similar amount is an H22.
Old 06-05-2003, 02:45 PM
i would think that you can put a h22a in it with the cams.
JOSH C. HARMON
K&W block sealer after failed head swap Bob9646 Thunderbird 4 07-19-2009 09:33 PM
head swap for lt1? kennynobodyrs Engine and Transmission 1 04-29-2009 07:36 AM
Mini-Me swap, a D15 Block + 1.6 Vtech head. Medabots JDM Motor & Parts info/chat 0 12-29-2004 03:32 PM
b20 head swap sohcvtecrx Prelude 9 05-25-2003 06:25 PM
vtech head swap, possible? joshknobel '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-16-2002 11:00 AM
