Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 03-07-2011, 11:16 AM
j43rsr2 j43rsr2 is offline
1998 dodge intrepid
working on a 1998 intrepid got the codes po134 po171 po154 and got all the codes taking care of except 1 po134 which it says its a oxy sensor just took it for a test drive after about 10miles it starts spewing black smoke and trying to stall out, then it clears right up after that any ideas would be very appreciative.
Old 03-07-2011, 12:09 PM
tempfixit tempfixit is offline
Re: 1998 dodge intrepid
P0134DodgeHO2S-11 (Bank 1 Sensor 1) Signal Remains At Center
I would check wiring at the sensor connector on either side for broken wire.The code means that the voltage is not oscillating so the pcm is using it's default setting and problably loading up bank 1.
Also make sure the fuel pressure regulator is not faulty, pull the vacuum hose to make sure there is not any fuel in line, if so replace.
Which engine???
Old 03-07-2011, 12:29 PM
its a 2.7 liter already checked out the fuel pressure reg but it still could be faulty thanks
1998 Dodge Intrepid smokes... shaneland Intrepid 23 02-14-2013 02:15 PM
1998 Dodge Intrepid HVAC Blower not working KingPCB Intrepid 0 10-11-2005 07:46 AM
1998 Dodge Intrepid 3.2L Engine Problems livfsu Intrepid 1 04-05-2005 09:47 PM
Problem with 1998 Dodge Intrepid sciumbato Cutlass Series 1 02-07-2005 07:20 PM
how to program keyless entry for a 1998 Dodge Intrepid ES? PSORC1 Intrepid 2 03-05-2004 04:11 PM
