Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 11-01-2004, 01:30 PM
shaneland shaneland is offline
1998 Dodge Intrepid smokes...
I have a 98 Dodge Intrepid and it smokes when I pull out.
I was told it may be the valve seals. Is this true? Could it be the rings? It doesnt seem to smoke when I go up hills just when I pull out...
Is there an easy fix?
What are some problems I can expect with this car? I have 107,000 miles and am wondering when can I expect the timing belt to fail???
What are some things I may have to fix?
Anyone have a site with technical service bulletins that I can read?
What is the best repair manual to buy?
Old 11-01-2004, 07:54 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1998 Dodge Intrepid smokes...
If you have blue smoke coming out of the tailpipe, you are burning oil, usually caused by oil leaking from the exhaust valve guides. The best service manual for the do-it-yourselfer is Haynes Repair Manual for Dodge Intrepid, Chrysler Concorde, LHS, and 300M for 2nd gen LH cars 1998-2004. The series number for that service manual is 25026.
Old 11-02-2004, 06:31 AM
thanks,
Am I to assume the rings are ok then??
IF I change the seals will the burning stop?
I just bought the car and dont know if synthetic is in there but I will clean the internals with motor flush and then add some synthetic oil and filter.
Is this the best I can do???
Old 11-02-2004, 07:45 AM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Intreprids are bad about oil leaks as well, is the smoke coming out the exhaust or coming from under the vehicle. One problem you can expect if they have not already been repaired is for the inner tie rod bushings and rack mount bushings to fail.
Old 11-02-2004, 01:21 PM
To test if your oil rings are ok, do a compression test. The minimum compression for the 2.7 liter engine is 100 psi.
Old 11-02-2004, 04:16 PM
will do.
NO drips under the car at all. NO drips or any fluids leaking in the engine compartment either.
Smoke is light any mostly at stop light acceleration. Not allot either. I bought motor flush and will tackle that tomorrow. I also bought a quality oil filter and synthetic oil, which I will tackle tomorrow as well...
Bought a Haynes too...
Compression test will attempt...
Old 11-02-2004, 05:36 PM
with the engine smoking (tailpipe) will the engine fail soon???
What could I do to prevent the engine from failing?
I noticed there is a fix out there but am wondering what exactly is the fix?
I noticed on a website the oil pump pickup screen gets clogged. Is there a different screen available?
What are the things you guys do to make sure yours last???
Thanks again!!!
Old 11-03-2004, 09:42 AM
rwood13 rwood13 is offline
don't panic, do the compression test FREAKnasty said it was 100 min, all cylinders should be close, they do not have to match exactly, let us know, if you don't know if the timing belt has been changed, change it, smoke when taking off is usually valve guide seals, when rings start to go it pretty much smokes all the time, to make it last, do the maintenance, do the maintenance!!!
Old 11-03-2004, 11:16 AM
I also cant find a timing chain in my area??? www.autozone dont have it www.advance auto dont have it
Where do I get one from???
Old 11-03-2004, 11:35 AM
ok I called advance auto and they can get me the kit for $512.00
Im just very worried because the insurance totalled out my breeze which had everything done so I could drive it for awhile (head gasket, timing, belts, wpump) and I bought the Intrepid which is in like new shape thinking the valve seals would be an easy thing... and I could have a fanatastic car no problem for little to no money at all...(spent what the insurance gave me on the car so yeah now I am a stuck)
Old 11-03-2004, 12:09 PM
Doing the valve guide seals yourself can be tricky, if you want to attempt it, you must be very careful because it involve you removing the valves just to replace the seal. If you aren't careful, you could drop a valve in the cylinder, and now you MUST take the cylinder head off to retrieve the valve. Also, if you bought a service manual from Autozone or Advance Auto Parts, turn to the section 2A on 2.7 liter engine servicing. It can give you all the steps you need on servicing your 2.7 liter even replacing the timing chain. With your engine, next time you change your oil, go with synthetic oil, preferably Mobil 1. That brand has the best anti-wear, anti-sludge additives period.
Old 11-03-2004, 01:15 PM
ok
I have air so I will pump up the cylinder with air before removing the locks and springs.
I bought havoline but since you posted I will take it back and buy mobil 1.
Old 11-03-2004, 08:42 PM
best way to add air to the cylinders is compressed air like from. You need a alot of air to hold those valves in place
Old 11-04-2004, 10:38 AM
yeah air compressor....have access to a restoration shop...
what I really need to know is if this engine is gonna blow? If you think it is I can start looking for another engine or working on a 3.2 swap...
Old 11-04-2004, 11:07 AM
ok, time to show my ignorance, if the 2.7 is running a timing chain, than I would not worry about changing it at 100K, a chain will far outlast a belt, the engine is not going to blow, do the maintenance, the smoke at idle just means you will have to check the oil more often
