Old 03-06-2011, 03:11 PM
daardema daardema is offline
171 code back again
I had 171, 303, 301, and 401 codes in my 2000 Windstar. I replaced the isolator bolts, plenum gaskets, and cleaned the egr ports. It ran much better. It still has a slight miss at low speed and I got a 171 code back. I suspect a vacuum leak but I can't seem to find it. The heater controls aren't completely functional. Is that a clue? Does anyone have an idea what to check for or where to look?
Old 03-06-2011, 03:30 PM
danielsatur danielsatur is offline
Re: 171 code back again
Need to perform a smoke test to pinpoint unwanted vacuum leaks, see http://www.automotiveforums.com/vbul....php?t=1061642
Old 03-06-2011, 04:44 PM
Thanks. I'll give it a go.
Old 03-06-2011, 05:31 PM
The only leak I found was the EGR solenoid. It was a minor leak. Is this normal?
Old 03-06-2011, 08:59 PM
It sounds like you found the problem!
The Following User Says Thank You to danielsatur For This Useful Post:
daardema (03-07-2011)
2002 Avalanche -- Code 171 (Bank 1 Lean) dartmouthrocks Avalanche 13 02-07-2012 09:37 AM
2002 Outback code PO420 back again ursina Outback 1 05-19-2009 05:32 PM
GRRRRR 171 & 174 AGAIN Goldlexus Windstar 37 10-25-2004 08:41 PM
Guess Whos Back...Back Again...Doris Back..Tell A Friend Dorikin 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 21 10-08-2003 10:27 PM
