Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 11-23-2010, 11:32 PM
dartmouthrocks dartmouthrocks is offline
2002 Avalanche -- Code 171 (Bank 1 Lean)
Could really use help with 2002 Avalanche (5.3 Liter), 4WD. 99,500 Miles.
Driving great until yesterday. Died while driving about 30 mph. Lost power, may have regained briefly, then basically died. Barely able to idle. Cannot rev up. It was about 22 degrees out and thought that bad gas might have been part of the problem. Replaced fuel filter today (could not puff through). Barely idles for a few minutes. Not able to rev up. Error codes are 171 (too lean Bank one). Any ideas? Perhaps a bad fuel pump? Major vacuum leak? Anyone seen a code 171 with a bad fuel pump? (I agree -- strange no Bank 2 code). Any help much appreciated. (Got above freezing today and problem continued -- did add dry gas.)
Old 11-24-2010, 04:26 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2002 Avalanche -- Code 171 (Bank 1 Lean)
I would check fuel pressure for up to specs.
02 sensors and vacuumn leaks and maf sensors can cause lean running codes to.
Also Clear code and see what comes back.
Post back fuel pressure readings.
MT
Old 11-26-2010, 10:58 AM
kenlwedel kenlwedel is offline
Exclamation Re: 2002 Avalanche -- Code 171 (Bank 1 Lean)
fuel pump pres.should be 60#to 65# if it is below 60 it will not start. if youturn ign.on &cant hear fuel pump run it is probley bad. have had same problem with 2002 avalanch, also with2000 escalade . good look
Old 12-01-2010, 11:44 AM
Thanks for your response. Checked out an Actron pressure guage setup from AutoZone--
Checked fuel pressure at port and it topped off at about 12 psi. Must be the fuel pump unless someone has experience with a pressure regulator causing such a drop?
Mike
Old 12-01-2010, 11:45 AM
Thanks--
Checked out pressure and it topped off at 12 psi.
Mike
Old 12-01-2010, 12:05 PM
MT-2500's Avatar
AF - Advisor
Mike
Where and how did it top off?
Jumper fuel pump and see what pressure goes to and how long it stays there.
Give us the fuel pressure with pump jumped?
Tank low on fuel or fuel filter pluged or fuel pressure regulator or even ground and hot wire to fuel pump can also lower pressure.
I like to plug or block off return line and check plump full pressure.
MT
Old 12-01-2010, 12:50 PM
Fuel filter is brand new. (post problem)
Vehicle has near new battery and turned over rapidly, spuddered (with couple of back fires) and did not start. Fuel pressure ranged from 10-12 psi. After 20 minutes -- psi remained at 5.
Would guess that the tank needs to be dropped to otherwise power the existing pump. (?)
Would appreciate info on how you recommend blocking off the return line to the tank if you still recommend that still being done. (plugged rubber line?)
thanks.
Old 12-01-2010, 02:51 PM
(Tank is 1/4 full.)
Old 12-01-2010, 05:35 PM
MT-2500's Avatar
AF - Advisor
thanks.
Always make sure on good 12 volt power and good ground to pump.
As to blocking return line a rubber line can be pinched off.
They make a special clamp tool for that so you do not damage line.
Or you can fabricate a plug for return.
Or go to fuel filter and disconnect line from tank and hook a gauge straight on the line from tank.
One other way to check full pressure is pressure at line to engine.
If pump is bad only replace with a Delphi oem type pump.
Airtex and other aftermarket pumps are junk.
Good luck and let us know how it goes.
Just do not run pump at full pressure 85-105 lbs over a second or 2.
MT
Old 12-04-2010, 11:41 PM
Thank you for the help. I checked the pressure from the pump after removing the fuel filter from the equation. It did not have sufficient pressure to empty gas from the tank (I was going to empty the tank into 5 gallon gas cans.) Not sure what happened to the previous 12 psi -- maybe the drop in pressure to nil was related to falling temps. Anyway, a new fuel pump solved the problem. Still somewhat surprised that the lean code only came in on Bank One. Did have trouble with the low temps fully removing the tank -- given the gas and return line being very stiff. Was able to accomplish the task by dropping the rear of the tank. Thanks again. (Post pump pressures in the mid-fifties.)
Old 12-05-2010, 07:02 AM
MT-2500's Avatar
AF - Advisor
You are welcome.
And thanks for posting back how it went and the fix.
Fuel pressure should be a little orver mid 50 range.
Specs on V T U engines is 55/62.
Key on engine off should go 61-62.
Engine running at idle 57-58 range.
Engine under load on road should hit 60-62.
If pump pumping full pressure and regulator not holding pressure to specs you may have a weak or bad regulator.
Lot of fuel pressure regulators problems on 5.3 engines.
Check vacume hose to regulator for gas in it.
If so regulator is leaking/bad regulator.
Good Luck
MT
Old 02-06-2012, 07:35 PM
joeysz06 joeysz06 is offline
i have an 02 silverado i notice i only get this code during low temps could it be the same problem? rough idle in cold starts rapid cylinder miss fire as well?
Old 02-07-2012, 08:38 AM
MT-2500's Avatar
AF - Advisor
Welcome to AF on your first post.
Your answer could be yes or no.
Same engine?
What is mileage and your fuel pressure readings?
This post is over 2 years old.
Your best bet is to go and post in the silverado forum and give all informaton on your truck
MT
Old 02-07-2012, 09:37 AM
Thank you
2002 Transmission Codes P700 and P740 rjs0421 2nd Gen 00-05 0 08-04-2009 09:28 AM
2002 QX4:Error Code P1320 Michael.Jones Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 07-20-2009 11:09 AM
02 avalanche stuck in 4LO tjmjr72 Avalanche 1 05-24-2009 08:30 AM
2002 Avalanche Parts For Sale YasiAngel Avalanche 1 06-13-2006 02:05 PM
Headers!! 2002 Avalanche. Harbinger225 Avalanche 1 03-09-2006 03:40 PM
Tags
avalanche , code-171 , fuel , pump , stalls
