Go Back   Automotive Forums .com Car Chat > Lincoln > LS | MKZ
Old 03-05-2011, 10:23 PM   #1
JOHNSJ22
02 Lincoln LS Vacuum leak
My 02 Lincoln LS seems to have a vacuum leak coming from behind or underneath the intake manifold. The car is a 3.0 litre V6 and I can hear the leak inside the vehicle coming from the driver side. It sounds like the defrost is on and underneath the hood sounds like an air leak. The leak seems to get louder as I accelerate and the car sputters as if the ratio of gas to air is off. Can anyone help me troubleshoot this problem and give me an idea of cost to fix it? I appreciate your help in advance.
Sincerely,
Jac
JOHNSJ22 is offline   Reply With Quote
Old 03-06-2011, 09:21 AM   #2
joegr
Re: 02 Lincoln LS Vacuum leak
Search, it's one of the bigger threads here. It's a common problem with the PCV hose/elbow.
joegr is offline   Reply With Quote
Old 03-06-2011, 09:41 AM   #3
brcidd
brcidd's Avatar
I've gone as far as to use a deflated balloon and lay it all around intake gasket, or any other vacuum hose. When hissing quits, and balloon is sucked in against the leak, you have found it...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
The Following User Says Thank You to brcidd For This Useful Post:
JOHNSJ22 (03-06-2011)
Old 03-06-2011, 12:29 PM   #4
danielsatur
1) Remove Air filter and wrap with glad wrap, and put back filter back in.
The idea is to block all the air Intake.
2) Remove brake booster vacuum hose from the brake booster.
3) Light a Black & Mild cigar and blow smoke into the Brake booster vacuum hose going into the intake, put thumb over hose end in between puffs of smoke.
4) Focus on PCV, EGR, and Intake system for smoke leaks.
Do a AF-serarch on DTC P0171
Also, see Similar Threads at the bottom of yours.
danielsatur is offline   Reply With Quote
The Following User Says Thank You to danielsatur For This Useful Post:
1997 LeSabre Vacuum Leak? nkmhockey LeSabre 3 12-10-2010 03:20 AM
Vacuum reservoir leaks on 95 park ave causes vacuum leaks aarcuda Park Avenue 0 07-18-2006 07:05 AM
Vacuum Leak ? aces1980 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 04-15-2003 03:38 PM
High Revving /possible vacuum leaks Carb88AccordLX Accord/TSX/Accord Hybrid 0 06-19-2002 10:36 PM
