Old 03-05-2011, 05:57 PM
jasonacook jasonacook is offline
was running, now it wont even turn over
i have a 1992 chev S10 with a 4.3 , 168k miles on it , i wa driving it around turned it off and went to start it up, everything lits up but it wont turn the starter over. i replaced the start and battery. any help would be great
Old 03-05-2011, 06:26 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: was running, now it wont even turn over
You don't say if this is an auto or manual trans but my first thought is the transmission interlock switch. In an automatic, this should be 2 wires that plug into the transmission.
The switch only allows power to go to the starter soleniod when the trans is in Park or Neutral. If the switch or circuit is damaged or interrupted, the soleniod will not receive power.
Old 03-06-2011, 01:59 AM
thank you for the info those wires are fine i bypassed the wire to the ignition, and the truck started right up.
2001 lumina wont even turn over lostwolf Lumina 25 04-29-2009 10:19 PM
'97 cavalier Wont even turn over- PLS HELP!! blucifixtion Cavalier Problem Diagnosis 6 04-07-2005 06:22 PM
1990 Lesabre wont even turn over shylow LeSabre 4 12-09-2004 10:50 PM
(94 1.8) car wont start, turns over but wont start. billclinton Corolla/Matrix/Voltz 2 11-09-2004 01:02 PM
WOnt even turn over "HELP" m.blakes LeSabre 1 01-14-2004 04:14 PM
