Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 02-28-2011, 05:38 AM
slayer5's Avatar
slayer5 slayer5 is offline
Question 95' V6 trans issues
I just bought a 95' 3.0 V6 4 runner that had overheating issues that caused head gasket to fail. I fixed all the reasons it was blowing the gasket with a new radiator & thermo. Now, temp no longer an issue but the automatic trans is slipping but has been getting alittle better as I drive it more. I noticed the trans fluid was pretty burnned when I replaced radiator..so will replacing the trans fluid & filter fix this issue ? Or could there be another issue ? My check engine light is also on, I will check the codes soon. I am getting horrible gas mileage, but probly from the slipping trans I guess. Any suggestions on a plan of attack to combat these issuses ?
Old 02-28-2011, 07:25 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 95' V6 trans issues
Changing the fluid and filter is a good place to start, but it may not fix the problem.
It could be clutches, solenoids, etc. in the trans.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Trans Service/Major Trans issues follow 00BlazLT Blazer 10 04-03-2006 08:51 AM
Trans Issues blazerowner Blazer 4 10-13-2004 02:57 AM
1994 LHS Trans issue ElGordo LHS 1 06-14-2004 05:07 AM
90 Auto 4unner trans issues tiki831 4Runner/GX470 5 04-08-2004 12:15 PM
92 STS Trans Issues HELP! Zltful Seville 4 01-20-2004 12:50 PM
