Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 05-04-2003, 12:09 AM
Zltful Zltful is offline
Send a message via ICQ to Zltful Send a message via AIM to Zltful Send a message via Yahoo to Zltful
Angry 92 STS Trans Issues HELP!
Hey folks,
Just got my 1992 STS out of storage and was all looking forward to cruising around only to find my baby has issues. First of all it wouldnt go into reverse. No grinding no noise whatsoever just no reverse. Neutral is fine. Put it into drive and find out I only have second gear no first no thrid no od just second gear. After some checking and calling around I find that the speed sensor MAY be the culprit. I have my brother swap out the speed sensor and lose the only gear I do have left. Here is where it gets goofier. We pull the trans fuse out of the underhood fuse panel and suddenly second gear is back. No other gears but second gear came back. Put the fuse back in and nothing. No trouble codes come up when you hook it up to the computer. I am at a total loss and starting to get a tad bit p!$$3d off. Any help or suggestions you guys have would be greatly appreciated. The transmission shop says its the tranny but my diagnosis skills as a heavy diesel mechanic say its something electrical or maybe shift servo related.
Thanks for any help.
Zltful
Old 07-03-2003, 05:31 PM
pkmaven pkmaven is offline
Transmission acting weird
The first thing you should check is the transmission fluid level. Check the transmission cooler hoses for leaks. P.
Old 10-27-2003, 08:13 AM
jim j jim j is offline
Banned
Same type problem with my 95 sls. Was your problem ever resolved?
Old 12-21-2003, 10:20 PM
enfeildjerry1 enfeildjerry1 is offline
no drive
First check fluid level/color. How long was BABY sitting, if it was a while a ball check could be sticking or the seals could be cracked. Where was BABY stored, small animals love to chew wiring. Your tranny shifts by solinoids, check the insulation!
Old 01-20-2004, 12:50 PM
fluteguy02 fluteguy02 is offline
Send a message via AIM to fluteguy02 Send a message via MSN to fluteguy02 Send a message via Yahoo to fluteguy02
Re: 92 STS Trans Issues HELP!
I had a 92 SLS with the same problem, Bad part is I ended up haveing the tranny rebuild. It took 6 times before it ever worked correctly! "Glad I only had to pay for it once"
94 Oldsmobile 98 Regencey Elite Issues HELP ME! nsman06 Ninety Eight 9 11-05-2009 08:23 PM
95 Towncar trans problems....help!!!! speeddemon_09 Town Car 4 09-20-2009 10:20 AM
94 Z24 auto trans issue HELP rockhardplace011 Cavalier Problem Diagnosis 5 08-14-2008 02:51 PM
82 olds 98 possible trans issue help? 82olds98 Ninety Eight 3 05-14-2008 10:24 AM
95 trans issues help slickroper Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 05-17-2006 02:39 AM
