Old 02-25-2011, 07:06 PM
Black_Blade Black_Blade is offline
2002 ABS and Brake lights coming on?
I just recently put all new brakes on my van, thinking this would take care of these warning lights that keep popping on every now and then. It had been a while so I figured it was time for brakes...
The brakes really weren't in all that bad of shape, but I put all new stuff on anyways, seeing as I had the stuff etc. The lights still both come on, which according to owner manual indicates serious brake problems/failure.
I read in older posts for older models about going around to each of the sensors and unplugging them and checking them for continuity. I guess this should be my next course of action? I hope it is not something wrong with the master cylinder or something. The brakes seem to be working fine.
Old 02-25-2011, 07:27 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 2002 ABS and Brake lights coming on?
Which light is on the ABS light, the e-brake light or both?
Check the Brake Pressure Switch under the brake fluid reservoir, there is a recall on it. The switch leaks brake fluid and causes the system to short when fluid goes into the electrical contacts.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 02-25-2011, 08:46 PM
olopezm's Avatar
Sorry you did mention both lights come on, if the problem was any of the sensors only the ABS light would be on, so I'm leaning towards a bad BPS.
Old 02-25-2011, 08:52 PM
tempfixit tempfixit is offline
olopezm, not sure what BPS means?
Old 02-25-2011, 08:54 PM
olopezm's Avatar
Brake Pressure Switch, that's why I wrote the first letters as uppercase in my last post, sorry for the inconvenience I won't be using any more acronyms in the future
Best regards,
Oscar.
Old 02-25-2011, 09:10 PM
kevink1955 kevink1955 is offline
Do they come on only when you do a quick stop then accelerate quickly, like a stop and roll at a stop sign when you are in a hurry. If so check the brake fluid level in the master cylinder. If my 96 is not almost at the top the sloshing of the fluid trips the float switch and sets the lights till next time you cycle the ignition.
I do not think the brake pressure switch has anything to do with the lights, it's part of the cruse control circuit. You can unplug it (and should if it has not been replaced) and it will have no efect on the vehicle except the cruse control will not work.
Old 02-25-2011, 09:12 PM
Best regards,
Oscar.
thanks Oscar I had a brain freeze and the acronym just did't register, for some reason I thought of brake pedal switch and that didn't make any sense to me. My mistake.
Old 02-25-2011, 09:46 PM
I have had the van in for the recall notice about the brake pressure switch leaking fluid. The master cylinder is topped right up too.
Both ABS and the e-brake lights pop on every once in a while, most times for no reason...driving along the highway. Yes, there have been times when braking quickly has set them off as well.
Old 02-28-2011, 07:24 PM
CnlK CnlK is offline
I would get an infrequent ABS light, would typically reset after a restart. Eventually the speedometer started acting erratic. Ended up replacing the vehicle speed sensor and have been good since. The standard code readers will not pull ABS codes, see if you can access a brake code reader.
2014 Chevy Equinox 2.4L, 2010 Grand Caravan 3.8L
Old 02-28-2011, 08:20 PM
olopezm's Avatar
You're welcome, we all have had a brain freeze from time to time LOL.
I've read about some users who took their vans in for the recall and problems persisted, the dealer did not install it properly or they just didn't replace it because it wasn't leaking YET... In case you haven't take a look at it just to be sure . If only the ABS light would pop on that could be something related to the wheel sensors but since it's not the case I will take a look at my manual and post back.
Seems a bit weird, but it's a Windstar, I guess everything can happen LOL, I'm familiar with the speedometer acting erratic because the same happened to mine, but never saw any brake lights on...
Best regards,
Oscar.
Old 02-28-2011, 09:21 PM
I have the code reader for CEL functions, but what kind of reader do you need for ABS codes? Didn't see any of those my local store...and its prolly another $300 drop of cash or more
Old 03-01-2011, 03:42 PM
My generic code reader won't pull the brake codes either. I did see one advertised in a sears/craftsman catalog for over $300. It claimed to read the engine and brake codes. When my speedo started acting erratic it would immediately trip the ABS light. My understanding is that the ABS system would need both the vehicle speed sensor, and wheel sensor inputs to operate correctly. The code reader that autozone uses for customers will not read the brake codes either, I asked. I recollect reading a post from someone who had some success cleaning the connectors on an ABS component that is located underneath the vehicle at the driver's side seat area.
Old 03-01-2011, 06:32 PM
Go to Actron website: they have a scanner for about $100 that will read abs code but make sure it will read them for your vehicle as it does not work on all vehicles.
Old 03-02-2011, 06:44 PM
eroosa eroosa is offline
My van had same problem and had to have it diagnosed at the local Ford Dealership.
It was the
ABS ecm.
The estimate was very expensive and since it only comes on once in a while I have decided to wait on it. Note that when the light is on your brakes still work as NON ABS brakes. It may also make sense to wait and see if your van passes the rear axle and sub frame inspections before you put any money into your van. Some people are getting buy out offers from Ford.
If you are not aware of these recalls there are several posts on this site.
Old 03-07-2011, 07:55 PM
WindstarMommy WindstarMommy is offline
I hope I am not intruding but I just wanted to tell you that I ordered an ABS Scan tool that will be here tomorrow. (79.99*) Total with tax was 86.00 + Free Shipping.
Here is the link:
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_ABS-Brakescan-Actron_16980008-P_N3389_T|GRP2018____
If you enter code P20 when/if you order that is what saves you *20% off the 99.99 price.
I hope it helps.
The Following User Says Thank You to WindstarMommy For This Useful Post:
olopezm (03-07-2011)
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
Battery Light and Brake light come on and A/C fan doesn't work Kayleigh Rodeo | Passport | MU 14 06-27-2009 03:22 PM
Alero ABS, Low Trac, Service Light and Brake Light coming on... Laz174 Alero 5 02-07-2007 09:13 PM
abs and track light comes on albert Young Grand Prix 10 09-09-2005 10:04 AM
Tags
abs , brake , lights , warning
