Old 08-16-2005, 12:12 PM
albert Young albert Young is offline
abs and track light comes on
The abs light and the track light comes on . Brakes seem to be working ok though?
Old 08-16-2005, 02:00 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: abs and track light comes on
normally, this indicates a bad hub bearing or abs harness. Take the car to a garage and have it scanned, that way you're not replacing something that isnt needed.
Old 08-16-2005, 03:49 PM
BigBL87's Avatar
BigBL87 BigBL87 is offline
Send a message via AIM to BigBL87 Send a message via MSN to BigBL87 Send a message via Yahoo to BigBL87
I had the same problem when I testdrove my car, they replaced the bearings, but from what I've read on other posts that is pretty rare. Like richtazz said, have it checked by a proffesional.
Old 08-16-2005, 08:16 PM
rbsteve rbsteve is offline
Those lights also come on when your battery is running low or isnt charging properly. If the bearings are ok, have them hook up the battery and alternator to see if they are functioning well.
Old 08-23-2005, 05:34 PM
Crashemup Crashemup is offline
I just replaced my wheel bearings thank god for extended warranty
Old 08-23-2005, 11:24 PM
BigBL87's Avatar
Wow, I'm glad my car's misfortune actually helped someone .
Old 09-08-2005, 03:30 PM
hillbilly bryan hillbilly bryan is offline
Send a message via Yahoo to hillbilly bryan
track light
i just had same problem i changed passenger axle they have got on passenger side fender wall wires to close to the belt drive it wore into mine very easy to get to look down from passenger side you will see where it plugs together and be able to see if it has got in to belt seen it done to mine and my friends mothers.
Old 09-08-2005, 03:33 PM
jeffs_GTP_sleeper's Avatar
jeffs_GTP_sleeper jeffs_GTP_sleeper is offline
Re: track light
could also be the wheel sensors.
Old 09-09-2005, 09:47 AM
richtazz's Avatar
all four wheel bearings have wheel speed sensors built into them. When the ABS and Trac off lights come on, it indicates a bad signal from one of the wheel speed sensors, so have it scanned to see which one is out of range, then check the harness going to that sensor, and if it checks out, you need a hub bearing.
Old 09-09-2005, 09:53 AM
Gmash1 Gmash1 is offline
Send a message via AIM to Gmash1 Send a message via Yahoo to Gmash1
Pretty common problem on Pontiacs. Wheel bearings are cheaply made, usually the bearing goes out before the sensor. Replace 2 at 65,000 miles. Bought one from AutoZone... BIG MISTAKE!!! first one the sensor went out after 2 mnths second one made clicking/clunking noise when turning, and the third one did the exact same thing, only worse and louder... Changed with a premium Napa bearing (SKF) haven't had a problem since.. AutoZone was very good about the return, but doubt they will do anything about the fact that the bearing they are selling is garbage.
Old 09-09-2005, 10:04 AM
richtazz's Avatar
I agree with Gmash, don't go cheapo on the bearing. Buy the name brand, preferably north american origin unless you like changing them, as the "white box" ones are JUNK
