Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 03-15-2009, 07:00 PM
freakyfire05 freakyfire05 is offline
emergency brake light comes on
recdently the E brake light comes on then turns off soon after what's up with that. where do i start
Old 03-15-2009, 07:18 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: emergency brake light comes on
Check the brake fluid level?
Old 03-15-2009, 07:23 PM
It's above the minimum line and the sensor is definitly all the way submerged
Old 03-17-2009, 11:38 AM
Davescort97 Davescort97 is offline
Escort guy
It's supposed to come on when the ignition is turned on to show that it is working. As soon as you start the car it will go out. This is the way it is supposed to work and there isn't anything wrong with the brakes.
Old 03-20-2009, 03:49 PM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
Check your pads.
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 06-11-2009, 07:19 PM
99fordzx2 99fordzx2 is offline
the e brake has nothing to do with the brake fluid. its connected by cable directly from the rear drums to the handle inside the car. when i slightly bump the handle in my car the light comes on. you can adjust the switch screw if need be by removing the center console. but everything seems fine to me by what your saying.
Old 06-12-2009, 12:41 PM
Airjer_'s Avatar
I guess I should have read that a little closer!
Deffinetely sounds like a normal bulb check. If it stops doing this (doesn't come on at all) or stays on all the time then there is definitely a problem.
Old 02-11-2010, 08:56 AM
FYI gentlemen, it turns out the cable had been stretched by the previous owner, which causes the breaks to not fully release (I.E) the light stays on. I think this forum needs some serious help.....
Old 02-11-2010, 10:19 AM
Airjer_'s Avatar
If the cable is stretched than the brakes are fully released but there isn't enough tension left to hold the handle down!
Tags
