Old 02-21-2011, 10:51 AM
pete44 pete44 is offline
Oil leak from Distributor shaft??? 92 Chevy Truck
Oil leak from Distributor shaft??? Possible? Truck also runs rough at low rpm..Have to run in D (4 speed auto) under 50 MPH to run better. I noticed when truck started running rough I developed a small oil leak (3 inches in diameter) overnight. This happens pretty well daily.
Thanks, Pete
Old 02-21-2011, 11:07 AM
j cAT j cAT is offline
Re: Oil leak from Distributor shaft??? 92 Chevy Truck
Thanks, Pete
most 20yr old vehicles leak . did you check the ignition components ?
oil leaks do not cause the engine to run poorly.
low power can be a bad converter .
how much oil do you add every 1000miles ?
If the distributor cap has oil IN IT , I would replace the distributor.
Old 02-22-2011, 01:30 AM
Schurkey Schurkey is offline
Thanks, Pete
Oil coming out the distributor shaft INTO the inside of the distributor is uncommon.
Oil drooling down the back of the engine because the distributor gasket is bad is not so uncommon.
Running rough can be a dozen things. What is the cranking compression pressure of all eight cylinders? What is the fuel pressure? Any codes or SES light? When was the last tune-up?
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 02-22-2011, 11:39 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Hey Pete,
Pull the vacuum line off your EGR valve and cap it. See if it idles and runs better?
Then replace the distributor shaft o-ring gasket and have the timing re-set.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-24-2011, 05:03 AM
jonnik jonnik is offline
Is it the distributor leaking or the oil pressure sending unit? Many Chevy engines have the oil pressure unit in the block next to the distributor.
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 12:44 AM
Transmision fluid leak from prop shaft universal Gerardjg M Bodies 0 10-14-2006 08:16 AM
oil leak at distributor mtbroadhurst Metro 1 10-11-2005 09:05 PM
1992 leaking oil from distributor shaft bigboyisme Regal 1 09-24-2004 02:05 PM
Oil leaking from oil filter....PLEASE HELP how2lose101 General Discussions 3 02-23-2004 06:19 PM
