Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-15-2011, 04:36 PM
wizardb wizardb is offline
four wheel drive wont work
my toyota four wheel drive stopped working in the hills it is an 89 with the 3.0 v6 engine. I have no vacum going to the actuator and i have traced it to the 2 solenoids and check valve and have no vacum to the check valve at all. From the check valve it goes to some saucer shaped thing that is connected to the exhaust manifold. i am not getting vacum from that thing, what is it and how do i test it?
Old 02-19-2011, 10:04 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: four wheel drive wont work
I'm not sure what you mean, can you take a pic of the "saucer shaped thing that is connected to the exhaust manifold" ?
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-20-2011, 11:13 AM
Thank you for your response, but i found the problem, i recently purchased this truck and the previous owner had put in a new engine and had the four wheel drive vacuum hose hooked to the AS REEDVALVE instead of a vacuum port. How i had vacuum for the 40 mins prior to it going out i have no idea but that was the problem and was able to get the hoses in the correct places for both parts. I still have to recheck all the rest of the lines to make sure that he didnt get any more crossed or hooked up wrong.
Old 02-20-2011, 07:20 PM
fourwd1's Avatar
AF -Advisor
Glad you figured it out!
I had never seen a saucer shape thing part of the ADD system before
89 4Runner - stock
Four wheel drive isn't working prcrbob Bronco 4 07-26-2006 02:17 PM
Four wheel drive button not working correct Gear Grinder Blazer 7 07-16-2006 08:28 PM
4 wheel drive wont work richs20a Blazer 1 03-11-2005 02:17 PM
Four Wheel Drive Not Working SWC1 4Runner/GX470 4 12-01-2004 04:05 PM
Four Wheel drive not working shockinjeep Grand Cherokee | Grand Cherokee SRT8 5 09-17-2004 02:39 AM
