Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 03-11-2005, 11:01 AM
prcrbob prcrbob is offline
Four wheel drive isn't working
Just recently acquired an '88 full size bronco with push button 4x4. The switch has power in and out and there is a definitive click in the dash. Heard that there is a motor that engages the 4x4. Is this motor bad, and ho do you remove it?
Old 03-13-2005, 05:21 PM
Truck Truck is offline
There's a motor inside the Transfer Case.
http://www.automotiveforums.com/vbul...d.php?t=352403
A little searching does it's share of good.
I hope this helps.
Old 03-16-2005, 10:03 PM
chip44 chip44 is offline
Re: Four wheel drive isn't working
Hey! I have a 1992 Bronco,and it acted the same way. I took a hammer and tapped on the side of the motor. Then it started working. I did it probably once a year, for 2 years. Now it has been working ever since. good luck!
Old 03-09-2006, 01:26 PM
bronc bronc is offline
make sure the fuse is good to start off with.there is a reset button on the passenger kick panel it will be the wire connection with the 2 wires on each side..?looks like a small module.?
Old 07-26-2006, 02:17 PM
tahonian tahonian is offline
have you found the problem yet? Also, mine does the same thing but only when it's very cold out and after 5 or 6 tries, it will eventually engage depending on how cold the weather is. Have you tried it in warmer weather.
