Old 02-13-2011, 05:25 PM
doctorhrdware doctorhrdware is offline
Angry Heater Core
I had just finished flushing the heater core out, and was putting the hoses back on. Guess what happened, the plastic connection for the input to the heater core broke off. Is that plastic connection piece replaceable, with out having to replace the entire heater core.
Old 02-13-2011, 05:47 PM
j cAT j cAT is offline
Re: Heater Core
just hook up the rubber hose to the heater core plastic tube with ca clamp.
get a hose that will work if too short now.
this is why when forum members ask about flushing the heatercore I say never screw with the hoses at the heater core but remove the engine connected hoses only.. with these hoses still connected to the heater core, the engine ends can then be used to blow out and drain into bucket the debris/coolant instead of the coolant running on every thing .
Old 02-13-2011, 06:09 PM
Re: Heater Core
I remember you . last dec 2010 your asking about heatercore poor heat..
this is what I said about the hoses. [copy/paste]
DO NOT REMOVE THE HOSES FROM THE HEATER CORE.....
Old 02-13-2011, 10:32 PM
ColoradoSilverado ColoradoSilverado is offline
Re: Heater Core
Are you talking about the connection on the firewall? If so, you can get the part at the dealer, Mine broke too.
My Truck:
2000 Silverado,, Z71
5.3 Ext. Cab, Long Bed
Original motor + transmission!
As of 3/21/14, I'm at 266,300+ miles!
My wife's Truck:
2005 F150 Lariat CrewCab
(Way nicer them my truck!)
Old 02-13-2011, 11:39 PM
Re: Heater Core
Yes I did and forgot that I ask the question so I did find a parts store that has one I will head out tomorrow and get the new part.
Old 02-14-2011, 08:25 AM
Re: Heater Core
when your working on any plastic auto parts it is best to work in a well heated area. cold plastic is very fragile.
Old 02-14-2011, 01:41 PM
Re: Heater Core
Since I do not have a garage that is not possible. The weather here in Chicago has broken, it was 45 degrees here yesterday and it is around 40 or so today. Also the early morning temperature was above 40. So that is not bad.
I also have the pliers that pinch off the heater hose without damage, so I only lost the antifreeze that was in the heater core and a little bit in the heater core hoses.
Old 02-14-2011, 03:31 PM
Re: Heater Core
so whats up with the heat output ? toes niece and toasty....
Old 02-15-2011, 07:04 AM
Re: Heater Core
Now that I have all the needed parts ans supplies to finish the job, including new heater core hose. I have one minor question now, how do I get the old heater core inlet/outlet hose connector off of the heater core inlet. I am trying not to brake the heater core. I only broke off the heater core`inlet connector. Thank in advance for your replies.
Heater Core Help emmaandleesmom SC/SL/SW 3 04-01-2010 11:43 AM
2002 Saturn L 300 heater core replacement Dadsvan LS/LW 0 03-22-2010 11:17 AM
97 k1500 z71 silverado, BLOW THE HEATER CORE???? kokopelli85 Silverado 6 01-12-2010 07:38 PM
1998 ACHIEVA Heater Core darkflame64 Achieva 1 12-31-2009 03:05 PM
smell antifreeze - NOT heater core samdavon Dakota 1 12-11-2009 12:19 PM
