Old 02-11-2011, 04:42 PM
woods80513 woods80513 is offline
Blazer Service 4WD Light
Sometimes when I start my 99 Blazer the Service 4WD light comes on and then goes right off like the other dash warning lights. When it does this properly the 4 button switch seems to work properly and I can change from 2WD to Auto or 4WD as normal - the appropriate button is lit up.
But sometimes when I start the car the Service 4WD light goes on, blinks off, and comes back on and stays on. When it does this there are no lights on the 4 button switch and it does not switch from 2WD, Auto, 4WD, etc.
It seems to matter if I turn the ignition on and wait about 3 seconds before starting the car. When I do that, the thing work properly (most of the time). But it's when I just turn the key and start the car immediately that the Service 4WD light stays on and the switch malfunctions.
Any guidence? Much appreciated.
Old 02-11-2011, 05:56 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Blazer Service 4WD Light
It sounds like a bad electrical connection. These units are known to get corrosion on the Transfer Case Control Module connector, The orange connector on the module for the 4 button 4WD trucks. Remove the passenger kick panel to get to the TCCM, remove the connector and look for corrosion on the pins.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 02-11-2011, 06:54 PM
fiserman fiserman is offline
I have a 2001 full size z71 chevy I put in the shop for that same problem and another problem. They had to replace the switch that changes it from 2 to 4wheel drive. He said it was a common problem they run in to with those switches. Don't know if thats the same problem your having but I hope this helps.
Fiserman
2001 Blazer service 4WD light on Ed Nicolette Problem Diagnosis 2 10-23-2007 05:11 PM
Service 4WD light on when AUTO 4WD pressed but works? Leifmb Problem Diagnosis 11 10-05-2007 01:40 PM
Service 4WD light and 4WD question theforce2723 TrailBlazer | Trailblazer EXT 2 08-21-2007 03:53 PM
2001 tahoe is stuck on 4wd hi and service 4wd light is on jolivera Tahoe 2 03-08-2006 04:06 AM
2000 blazer service 4wd light on denise2580 Blazer 4 07-11-2005 03:20 PM
