Old 07-04-2007, 09:22 AM
Ed Nicolette Ed Nicolette is offline
2001 Blazer service 4WD light on
We own a 2001 Blazer and the service 4WD light just came on and I need a direction to go to find out what is wrong, Can anyone make suggestion?
Thanks
Old 07-04-2007, 11:11 AM
jetfixerdw jetfixerdw is offline
Re: 2001 Blazer service 4WD light on
When the service 4x4 light comes on their is a problem in the system. It can be the Module, or the transfer case shift motor usually giving you that light. It is usually the module but I have read in various posts other ways to somehow bring the system back to life. Disconnecting the battery for awhile to reset the module is sometimes a way to reset it. If that doesn't work and the light comes right back on It might be the transfer case motor stuck. Hope this helps. If all else fails the dealer has specific testers to tell which component is at fault. I just replaced my Module for the same reason.
2000 lt 4x4 100k
Old 10-23-2007, 05:11 PM
Joe Buzzin Joe Buzzin is offline
Question Re: 2001 Blazer service 4WD light on
Can you tell me about how much the Module might cost?
Thanks in advance
