Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-11-2011, 05:34 AM
CrownVic03 CrownVic03 is offline
Headlights randomly turn off
I noticed in the past month that my headlights randomly turned off for 15 seconds. This happened 3 times in the month. Its both of them and when I try to turn it on and off it will not work. I even tried to set it on the auto on option (all the way to left on 03 Vics)
Anyone know what this could be?
Old 03-17-2011, 08:15 PM
reddcad reddcad is offline
Re: Headlights randomly turn off
This is typical on Crown Victoria 03-04 .
it is the headlight power unit going bad $339.00 from FORD.
Old 03-18-2011, 07:41 AM
Stick462 Stick462 is offline
LCM is failing and needs to be replaced or repaired .Type in your explorer search ( light control modul repair) and fix it your self .LCM is just above your gas pedal >>>>>>>>>>black box with wires coming out of it.
Old 09-03-2011, 09:38 PM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
I had the same problem develop in my '99 CVPI. I started counting pennies for the LCM &/or Headlight relay. Then one day it wouldn't start at all. I discovered the stock (@ 232K mi), positive battery terminal clamp was badly corroded, and nearly eaten in two. A new REAL TYPE battery clamp from Wally World ($1.59) fixed both problems! I have a new clamp for the negative post for when I get time to change it too.
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Old 09-04-2011, 12:55 AM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
+1 on the battery before spending big money on an LCM.
I had the same problem in my Town Car and turned out to be a deffective battery.
You can have yours tested at most autoparts stores.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
Headlights turn off when A/C turned on. Assassin85 Grand Prix 5 08-13-2010 09:34 AM
97 Prelude randomly turns off on the freeway! HELP!!! 92teggsr Prelude 6 02-06-2009 10:26 PM
Blazer Randomly Turns Off SBlazerNCS Blazer 7 12-02-2004 08:20 PM
My Left HeadLight wont turn off!!!! Really Random... Rodeorulz General Discussion 2 06-05-2004 11:07 PM
